when clutch is pushed in the car wont start
when i push my clutch in and turn the key it wont start. its like the clutch aint even pushed in then after about a minute it will start just fine after i push it in and turn the key again. what is the problem? any help will be much appreciated
Sounds like its your clutch saftey switch. its a sensor that tells the ecu that the clutch is pushed in. you can unhook it and it will start without the clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Sounds like its your clutch saftey switch. its a sensor that tells the ecu that the clutch is pushed in. you can unhook it and it will start without the clutch. </TD></TR></TABLE>
peacexisxfree
May 15, 2006 05:37 PM
