Code 7 problems
Old Jul 15, 2005 | 10:42 AM
Mach69's Avatar
Default Code 7 problems
I always have these weird codes. Anyway, I searched and found similar situations but none exactly like mine.
I obviously have a code 7. The CEL only turns on when I am at WOT. I can also just turn off the car, and when I turn it back on, the CEL turns off. But, when I go to check the ecu, it is still flashing the code, but the CEL is not showing. I also 'calibrated' the tps and at idle I was at ~.49v and at WOT I was at more than 5v. The car does not bog, the engine runs normally like it should, except there is no vtec because of the code 7.
What can I do to solve this? I know the wiring is good and connections are good, because I the moved the tps around and sometimes I would instantly get a code at idle.
Should I get a new tps, put it on and set it to .45v and see if the code comes up or still with this one?
Old Jul 15, 2005 | 10:45 AM
CBURKE's Avatar
Thats what i swould say to do.
Old Jul 15, 2005 | 09:43 PM
Mach69's Avatar
Default Re: (CBURKE)
bump up
Old Jul 16, 2005 | 12:47 AM
SiBuddy00's Avatar
Default Re: (Mach69)
bump i got the same damn problem, good power, lines are good, but code comes on when the rpms fall while shifting gears. also... how do you adjust it?
Old Jul 16, 2005 | 08:55 PM
Mach69's Avatar
Default Re: (SiBuddy00)
Anyone... please!
Old Jul 17, 2005 | 12:58 PM
Mach69's Avatar
Bumping it again.
Old Jul 19, 2005 | 11:47 AM
SiBuddy00's Avatar
fixed mine! my throttle body wasn't like, stuck shut... but there was some corrosion (spelling) in the throttle boddy, causing it to be sticky when it was closed. I adjustd the close throttle screw just a thread or two so it woudn't be sticky anymore and the code went away.
Mr.Death
Apr 30, 2010 05:51 PM
lazyxmofo
Feb 13, 2009 06:43 AM
vtechrex
Jul 10, 2006 06:21 PM
EKtypeRhaTcH
Jul 9, 2003 11:37 AM
hondaZvic
Sep 2, 2002 10:58 AM
