can't increase sensitivity on JL amp
I have 2 12" JL audio W3s in a sealed box powered by a JL audio 500/1 mono amplifier. I also have a Rockford Fosgate punch capacitor hooked up along with a hi lo converter because I'm still using the stock head unit. Whenever I try to increase the sensitivity of the amplifier, the subwoofers would start rattling when I turn off the headunit. So right now, I'm not getting that much bass because I can't increase the sensitivity on the amplifier. Before the JL amp I was running a RF punch 500 and I didn't have a problem with the subwoofers rattling when I turned off the headunit. Would getting a pioneer deck solve the problem or should I get everything rewired or what? Thanks
*I had everything professionally installed at Pacific Stereo, a local stereo shop that is somewhat reputable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HypnoticR »</TD></TR><TR><TD CLASS="quote">I have 2 12" JL audio W3s in a sealed box powered by a JL audio 500/1 mono amplifier. I also have a Rockford Fosgate punch capacitor hooked up along with a hi lo converter because I'm still using the stock head unit. Whenever I try to increase the sensitivity of the amplifier, the subwoofers would start rattling when I turn off the headunit. So right now, I'm not getting that much bass because I can't increase the sensitivity on the amplifier. Before the JL amp I was running a RF punch 500 and I didn't have a problem with the subwoofers rattling when I turned off the headunit. Would getting a pioneer deck solve the problem or should I get everything rewired or what? Thanks
</TD></TR></TABLE>Using an aftermarket HU with pre amp outputs will make a huge diff. in SQ, right now you may be over saturating the input stage of the JL amp, did you know that the 500/1 has a speaker level input? that is what the input voltage switch is for, [above the RCA inputs] http://www.jlaudio.com/amps/pdfs/500_1.pdf you don't need the "hi lo converter"
94
94
JohnnyEF
Audio / Security / Video
Nov 26, 2006 12:04 PM
