cel 4 help
Old Jul 14, 2005 | 05:43 PM
lightcrx's Avatar
Default cel 4 help
i got a new crx with a jacked harness. so i changed the whole harness(interior/engine bay) now im getting a code 4.
the harnesses are from a 88 crxsi engine starts but wont rev above 3000, now i know that code 4 is ckp sensor, org and wht wires so i checked the ohms as the helms said and got 380 sumin helms says 350-500. iv tried a known working dizzy and i have also tryed 3 different ecu's. does any one know what else can cause this prob?
car is a 89 dx
ive also tried to run wiring direct from the dizzy to the ecu to no aval
thanks for the help
-joseph
Old Jul 14, 2005 | 06:11 PM
aaronhume's Avatar
Default Re: cel 4 help (lightcrx)
get a new end wire for the ecu plug thats what fixed my problems with the distributor wiring... and make sure you don't screw them up when depinning
Old Jul 14, 2005 | 06:39 PM
Ch3mik's Avatar
Default Re: cel 4 help (aaronhume)
whats an end wire?
Old Jul 14, 2005 | 07:05 PM
lightcrx's Avatar
yea what do you mean end wire? like the plug?
anyone else??
i really need to get this problem solved
Old Jul 14, 2005 | 09:08 PM
lightcrx's Avatar
this fourm moves fast
Old Jul 15, 2005 | 11:58 AM
lightcrx's Avatar
up, well i guess ill try to get a new harness
thanks
-joseph
Old Jul 16, 2005 | 04:28 PM
Ch3mik's Avatar
Default Re: (lightcrx)
same thing here. mine wont fix. i replaced the dist already. im gettin pissed,.
Old Jul 16, 2005 | 10:30 PM
lightcrx's Avatar
i just changed the harness and still the same.
wtf, im begining to think this is a lost cause lol
what have you tryed already?
thanks
-joseph
Old Jul 16, 2005 | 11:56 PM
Ch3mik's Avatar
well. i checked my wiring cuz its sloppy from the last owner. the car is a 90 HF
d16z6
obd1 conversion
p28 ecu
tried a new dist and no change, retimed it cuz it felt off, no change. tomorrow im going with a friend of mine that has a perfect 95 civic and were gonna test his dist on it. if his dist fixes it then i got a bad dist . ill post up wat happens
Old Jul 28, 2005 | 10:36 PM
aaronhume's Avatar
Default Re: (Ch3mik)
sorry bout not answering... if you still are having problems, it could be at the ecu plugs... thats what I was trying to talk about... when I de-pinned my wires at those plugs, I messed tons of the connections up, and when i replaced them, it worked fine... I even got a new distributor before as well.
slowesteg
K Series
Jul 4, 2018 06:47 AM
SoFreshh
Dec 7, 2009 10:08 PM
SiR Inspired ED7
May 6, 2008 08:24 PM
crxfreak1117
Nov 28, 2007 05:56 AM
stockegsix
Apr 12, 2002 11:20 PM
