Bolt Problem 99 Civic SI
I am going to be doing my very first honda b16a2 engine swap by myself (wiring) assembly etc.)on my 93 Civic CX Hatch and i was wondering if i can use bolts from my d15b8 engine on to my B16A2 engine. I know it sound stupi, but i was wondering which ones i can use like mounts, tranny, dizzy, intake and exhaust studs and nuts and bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radyjr »</TD></TR><TR><TD CLASS="quote">I am going to be doing my very first honda b16a2 engine swap by myself (wiring) assembly etc.)on my 93 Civic CX Hatch and i was wondering if i can use bolts from my d15b8 engine on to my B16A2 engine. I know it sound stupi, but i was wondering which ones i can use like mounts, tranny, dizzy, intake and exhaust studs and nuts and bolts. </TD></TR></TABLE>
only bolts u will need from your old setup is all the motor mounts that goes to the chassis
when i did my first swap
i used this guild http://www.c-speedracing.com/h...p.php
but i rarely looked at it. the whole swap is common sense on what to do
the thing was i went out and bout a bare block then a loaded Head. what iam asking in short terms is if for like the AC Bracket that goes bolted to the block can i use the one from the d15 on the b16a2 block, alternator bolts from the d15 bracket to the b16a2 alternator bracket etc. i don't wanna go end up going to the dealer or a local bolt and nuts company had have to give them thread measurents and all kind of bull (Fastenal) just to buy a bulk just to bolt everything up.
Guest
Posts: n/a
u can use the tranny to block bolts, don't know about exhaust studs, just try it anyway, if it doesn't thread in by hand then it's not right.is your car stick or auto?your going to need a b series rear bracket also, from a teggy. i don't know if the 99-00 si works or not
my car is stick, i have everything del sol ac bracket, rear, front, tranny brackets. will bolts like from the tranny be able to be used for the b16a2, same with the other misc bolts
i just got the rest of my stuff that i needed, alternator, dizzy, itr tranny, skunk2 intake, bbk throttle body with tps, etc. but i don't have the bolts for my b16 series engine to bolt everything together
gsxr1k05
Sep 24, 2006 07:52 PM
