How to install Amber Corners
Open hood, unscrew mounting tab screw, pull corner light out, disconnect the light bulb from the cornerlight and connect it to your amber corner, slide amber corner in, screw mounting tab screw in, Repeat steps for other side
P.S. the corners should sit flush with your headlights, so if there is a gap you probably didn't slide it in right.
Pop the hood,right next to the headlight and your cornerlight where they meet there is a little screw unscrew it and then pull out your corner light then twist the socket plug that goes onto the corner light then reinstall it.
