b16 swap ecu problem
Old Jul 14, 2005 | 11:55 AM
crx90rcr's Avatar
Default b16 swap ecu problem
ok well i had a d15b2 then i did a mpfi swap and it ran fine till i blew my diff. i decided to do a b16a swap and now its in and it gets spark and everything seems fine. but theres no fuel ok so i turn on ignition and the pump isn even purging. i decided to put the d15s ecu in and now it gets fuel but i dont want to crank it with the d series ecu in. so y would the d series ecu let the fuel pump purge but the b series not and the
d series ecu pm6
b series ecu pr3
Old Jul 14, 2005 | 03:36 PM
crx90rcr's Avatar
Default Re: b16 swap ecu problem (crx90rcr)
bump
Old Jul 14, 2005 | 10:02 PM
crx90rcr's Avatar
bump
Old Jul 14, 2005 | 10:04 PM
crx90rcr's Avatar
well so what im asking is..... what is wrong? is the ecu pins for the b16 fuel pump in a diff spot than the d16s ecu
Old Jul 14, 2005 | 10:56 PM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx90rcr &raquo;</TD></TR><TR><TD CLASS="quote">well so what im asking is..... what is wrong? is the ecu pins for the b16 fuel pump in a diff spot than the d16s ecu </TD></TR></TABLE>
Yes, they ARE the same pins. No, they are not in a different spot.
If the PR3 isn't priming the pump, you may have a bad ecu. Do you get any check engine lights?
Old Jul 14, 2005 | 11:06 PM
crx90rcr's Avatar
Default Re: b16 swap ecu problem (Bunger)
yes its like one flash but its like 3 seconds or 2 seconds long
Old Jul 14, 2005 | 11:12 PM
Bunger's Avatar
If its a long flash, then its code 10, which is IAT (intake air temp). Shouldn't be causing an issue with fuel pump priming.
Old Jul 14, 2005 | 11:14 PM
crx90rcr's Avatar
but isnt there one longer flash that meens ur ecu is bad or something
Old Jul 14, 2005 | 11:16 PM
Bunger's Avatar
solid is bad ecu
Old Jul 14, 2005 | 11:17 PM
crx90rcr's Avatar
how long will it stay solid
Old Jul 14, 2005 | 11:27 PM
crx90rcr's Avatar
i think it has to b a bad ecu what else could it b considering the d series ecu works and the b series always flashes that 3 sec flash
Old Jul 15, 2005 | 08:43 AM
crx90rcr's Avatar
bump
Old Jul 15, 2005 | 03:52 PM
crx90rcr's Avatar
bumpizzle
Old Jul 15, 2005 | 10:27 PM
crx90rcr's Avatar
i still have the same problem it ended up i have no wire at A10 on the harness and it says on a website that hasport has as a link that its the preasure cutoff solenoid and it says i need to take A6 and pin it at A10 i did it and still throws that code 3 second long flash 10?
Old Jul 16, 2005 | 09:17 AM
crx90rcr's Avatar
no help well so what should i do get a new ecu and start from there
well the motors from hmo so do they have problems like this alot
Old Jul 17, 2005 | 07:59 PM
crx90rcr's Avatar
weres my help i got a couple kids to fix there cars in the last 4 days on this site and not one other person besides bunger can help me
Old Jul 19, 2005 | 07:43 PM
crx90rcr's Avatar
bump i need a car that runs
Old Jul 24, 2005 | 06:21 AM
crx90rcr's Avatar
any one in chicago area want to help figure this out there mite b some money involved
Old Aug 4, 2005 | 03:06 PM
crx90rcr's Avatar
i just called hmo and they received my ecu today that i sent them. they bench tested it and said there sorry that they sent me a bad ecu. so the car should start soon lol they sent me a new one overnight
Old Aug 4, 2005 | 03:23 PM
Burlyirishdude's Avatar
good luck! Yeah any more codes and you should be able fix them like bam...
Old Aug 4, 2005 | 09:14 PM
crx90rcr's Avatar
Default Re: b16 swap ecu problem (Burlyirishdude)
i kno 4 real im only barely 17 and i think i kno every code by hart and im already swapped i think im doen ok i guess o and i have a q my motors radiator hose is sapposed to b a larger diameter than the diameter of the radiator so what do i do
speedsk899
Jun 13, 2014 05:07 AM
averyvm
Mar 11, 2014 06:06 PM
redline32
Engine Management and Tuning
Jul 9, 2009 10:32 PM
98k20ex
May 9, 2004 11:07 PM
hybridb18
Apr 9, 2004 04:09 AM
