is it possible to remove tranny from crx?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snow white »</TD></TR><TR><TD CLASS="quote">is it possible to remove the crx tranny out and swap it with another without taking the motor out?</TD></TR></TABLE> yes just place a jack (with a block of wood) under the motor and unbolt the tranny and drop it to the ground (and as far as tranny's go, you would need a tranny from the same series as the motor its going to i.e. d series=d-series and b-series=b-series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingKhong »</TD></TR><TR><TD CLASS="quote">good luck it sucks cus i did it by myself</TD></TR></TABLE> it does suck, but i never said it would be fun
Yeah its possible and I agree with the other guys it sucks. Your going to have to take off the front, rear and the passenger side engine mounts also. I just did mine about two days ago, but just make sure the new tranny is the right series. I switched in a 91 si tranny into my 90 HF.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrXThang »</TD></TR><TR><TD CLASS="quote"> I switched in a 91 si tranny into my 90 HF. </TD></TR></TABLE> i bet your lovin the si right now
Yeah its tight, but I still kept the HF axles on it. Do you think I should change the axles to the SI ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrXThang »</TD></TR><TR><TD CLASS="quote">Yeah its tight, but I still kept the HF axles on it. Do you think I should change the axles the SI ones?</TD></TR></TABLE>
If you do you will need the hub and spindle assembly from a Dx or Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrXThang »</TD></TR><TR><TD CLASS="quote">Alright thanks, also I believe the si tranny will go into a ZC motor?</TD></TR></TABLE> yes it will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snow white »</TD></TR><TR><TD CLASS="quote">i know..some guy is trying to put an si tranny with an ls..lol..i was laughing at him.</TD></TR></TABLE> laugh at him for me also
(and then explain to him why it wont work)
Its not that hard, pull the axls, remove some bolts and drop the tranny out. If you guys want to talk about a pain in the a$$, try dropping an auto tranny out the bottom. I will never have to do that again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdocrx »</TD></TR><TR><TD CLASS="quote">hardest thing would be lining it back up with the shaft and dowel pins</TD></TR></TABLE>
i'll give a hell yeah to that...big pain in the ***. sometimes that takes longer than taking the tranny out to start with.
it lined up at my first time but like i said its so much easier with a lift. did a b and a D tranny with a lift and one B without and i almost gave up when i did it without the lift. as stated nothing was hard to do when i had the lift. the hardest was getting that back starter bolt for me off
If you cant get a lift, get a second set of hands for putting the tranny in. I had to lift mine in from the top while working a floor jack underneath the tranny with my foot to get it in.
JDMroyEG5turbo
Mar 15, 2006 07:29 AM
91 ZC hatchback
Jan 17, 2006 02:54 AM
HT Chaplain
10
Apr 16, 2005 07:53 AM
sleepyhamsterlx
11
Mar 27, 2004 12:56 PM
