type r rods into B16
Old Jul 14, 2005 | 08:44 AM
dohcMONSTER's Avatar
Default type r rods into B16
im in the process of building my next motor and was curious if there would be any advantage to pairing my CTR pistons to ITR rods instead of just the stock b16 rods. would this even be worth it? or should i use the money for something else.
TIA
Old Jul 14, 2005 | 09:29 AM
JDM99Hatch's Avatar
Default Re: type r rods into B16 (dohcMONSTER)
there will be a difference in stroke, i think the ITR rod is longer then the b16, so it will prolly mess with your deck height, u might need CTR rods, they are better anyways more nickle in them.
Old Jul 14, 2005 | 09:47 AM
Hybrid96EK's Avatar
Default Re: type r rods into B16 (JDM99Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM99Hatch &raquo;</TD></TR><TR><TD CLASS="quote">there will be a difference in stroke, i think the ITR rod is longer then the b16, so it will prolly mess with your deck height, u might need CTR rods, they are better anyways more nickle in them.</TD></TR></TABLE>
Classic...
For one, the pistons themselves will not mess with deck height. Deck height is dictated by the block itself and can only be changed by either decking the block, or adding a deckplate. Now, piston to deck height can be altered by changing rods.
Two, you could not run ITR rods in that engine.... Piston will come out of the hole a good deal and I am sure you can guess what would happen from there. B16B's share the same block as the B18C5 and thus have a higher deck height over the B16A.
Third, the rods do not have more "nickle" in them. Not sure where you dug thus up. They are specified as "high crome carbon steel" from Honda. Yes, they are stronger, but in most cases for mild to moderate NA builds, stock rods will suit just fine.
Old Jul 14, 2005 | 12:27 PM
Default Re: type r rods into B16 (Hybrid93Eg)
gotcha thanks much
Old Jul 14, 2005 | 12:33 PM
one more quick question for you about rods, i would get the same result with GSR rods and type r rods correct? couldnt use either?
Old Jul 14, 2005 | 01:17 PM
battle951sedan's Avatar
^yep.
also, high chrome carbon steel aka chromium
Old Jul 15, 2005 | 03:18 AM
JDM99Hatch's Avatar
thats what i was tryin to explain that the rod is to long and the piston will come out of the block , the deck height of the block is to short.
Old Jul 15, 2005 | 04:27 AM
91civicDXdude's Avatar
also, rod length has nothing to do with stroke. stroke is determined by the crank only.
Old Jul 19, 2005 | 12:22 PM
Akiraboy's Avatar
Default Re: (91civicDXdude)
EDIT: nevermind
Modified by Akiraboy at 2:11 PM 7/29/2005
GEN2 LS
Aug 15, 2009 07:51 AM
EFMAN
Feb 3, 2005 06:16 PM
evad
21
Dec 30, 2004 06:55 AM
hybridnorth
10
Oct 25, 2004 10:38 PM
Fleas_Ef
Aug 4, 2004 03:55 AM
