Tuning - correcting hesitations
Old Jul 13, 2005 | 09:48 PM
Qveon's Avatar
Default Tuning - correcting hesitations
Ok when i floor it, it pulls hard up from like 4000-5000. then it kinda hesitates like someone grabbed my rear bumper till like 6500 then it pulls hard again till redline.
Not being engine specific, but going on theorys and principles, what causes this lack of pull to momentary happen?
Old Jul 14, 2005 | 07:10 AM
B6tPoweredMx3's Avatar
Default Re: Tuning - correcting hesitations (Qveon)
First what are you running for engine management? Do you have a wideband ?
Old Jul 14, 2005 | 07:56 AM
IN VTEC's Avatar
A sudden and significant decrease in power output. It's probably associated with a LO->HI cam changeover. Could be far too lean (lambda > 1) or not enough ignition advance on the HI cam.
Try it with the x-over moved up higher to see how consistent the power output is beyond the original x-over point.
What engine, ECU, and cams are you using?
Modified by IN VTEC at 1:16 PM 7/14/2005
Old Jul 14, 2005 | 10:02 AM
Qveon's Avatar
h22a, jp13 w/ e-manage, stock cams, jrsc @6psi, wideband
so if under 6psi i am pulling -5º, then i should pull less timing while in vtec? wouldn't that lead to detonation problems?
Old Jul 14, 2005 | 10:24 AM
IN VTEC's Avatar
Default Re: (Qveon)
It could also be a boost leak at the manifold. Does the boost gauge hold the 6psi all the way through?
Old Jul 14, 2005 | 10:52 AM
Qveon's Avatar
it holds 5psi with my 2.5" catback and testpipe
Old Jul 14, 2005 | 11:38 AM
IN VTEC's Avatar
Default Re: (Qveon)
What about plug gap?
If you're going to put timing back into it....add two to three degrees back, one degree at a time. If you don't see positive results by that time, move on to something else.
A motor can run like poo if you don't have enough timing in it. And, since I can't judge how much timing you're actually running, you're just going to have to work slowly and carefully.
I'm kinda curious...does the e-manage show pressure vs. RPM or TPS vs. RPM on the main airflow adjustment chart?
EJ1B18c
Jul 24, 2010 07:15 AM
jdm knight
Jan 26, 2009 08:23 AM
TeamCracka
Sep 9, 2004 07:46 PM
TRuST
Jun 3, 2003 01:15 PM
