Midrange manifold.
Old Jul 13, 2005 | 03:33 PM
GeeGee's Avatar
Default Mid-range manifold.
I built the manifold for a set-up that aim at mid-range power that allow quicker spool. The equal lenght manifold was out of the question due room issue and the later spool time, the external wastegate will be placed infront with an L. This will go on a bottom to top fully built b16 with a sc61 for now. I'm looking for constructive criticism on the manifold.
Here are the pics of the penetration
Any constructive criticism will be greatly appreciated.
Old Jul 13, 2005 | 03:58 PM
Rtype16's Avatar
Default Re: Mid-range manifold. (Krabbypro)
Looks good, but I would have passed cylinder 2 and 3 over the top to the front and 1 and 4 to the back. Shouldn't take up that much more space and it will help being that much closer to equal length.
Old Jul 13, 2005 | 04:11 PM
Engloid's Avatar
OG Fabricator
Nice work on the internal penetration! You rarely see that on manifolds. Often, even the top names in manifolds will have about 1/8" penetration (disrupts flow) rather than just melting down the inside as you did.
Looks like the outside could use a little practice, but doesn't look like anything to be ashamed of either.
Overall, looks nice.
Old Jul 13, 2005 | 04:18 PM
GeeGee's Avatar
Default Re: Mid-range manifold. (Engloid)
Thanks Engloid, yeah I'm still trying to be more consistent on the outside.
Old Jul 13, 2005 | 05:20 PM
Engloid's Avatar
OG Fabricator
I've seen guys make a living welding pipe and not be able to get the root pass to look like that.
The company I'm working for now is really hurting for good help, but most guys that come in to test just suck.
Old Jul 13, 2005 | 06:08 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Mid-range manifold. (Rtype16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Looks good, but I would have passed cylinder 2 and 3 over the top to the front and 1 and 4 to the back. Shouldn't take up that much more space and it will help being that much closer to equal length.</TD></TR></TABLE>
^what he said.
Old Jul 13, 2005 | 10:29 PM
tealjdmcrx's Avatar
Im looking for manifold like your I also have space issues . looks good
Old Jul 13, 2005 | 11:17 PM
ExploitedRacing-HR's Avatar
Looks very nice! what kind of welder are you using?
Old Jul 14, 2005 | 09:29 AM
HaTcH_BmX's Avatar
Default Re: (ExploitedRacing)
me like !!!!
Old Jul 14, 2005 | 10:52 AM
S2KP's Avatar
Looks good
Old Jul 16, 2005 | 03:12 PM
mamaboy's Avatar
swing #2 and #3 over and run #1 and #4 where 2 and 3 are @ right now. how low does the turbo sit?
Old Jul 17, 2005 | 12:36 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Mid-range manifold. (mamaboy)
looks just like the lovefab mini-me. it offers quicker spool up versus a true equal length manifold and it has a true merge collector. and i must say i am very impressed with the penetration you got. props!
Old Jul 17, 2005 | 05:58 PM
GeeGee's Avatar
The return port on the turbo is about 2" higher than the top of the oil pan, I tried to keep the collector short to keep the turbo high enough for return line.
Old Jul 19, 2005 | 07:07 PM
RIP V8s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">I would have passed cylinder 2 and 3 over the top to the front and 1 and 4 to the back. .</TD></TR></TABLE>
same, more of an equal length design
bart simpson
Welding / Fabrication
10
Sep 18, 2008 12:59 AM
thenick
Jan 23, 2005 05:55 PM
project dc2
Mar 29, 2004 10:05 AM
JDEM1
Oct 18, 2002 10:52 PM
1337 Si
Mar 29, 2002 11:00 AM
