GSR internals in a LS, HELP
Old Jul 13, 2005 | 01:22 PM
slambedcivic's Avatar
Default GSR internals in a LS, HELP
Will a GSR rotating assembly BOLT right into a LS block?
Old Jul 13, 2005 | 03:21 PM
gsrious's Avatar
so you want to put in a gsr crank, gsr rods, and gsr pistons...
sure go ahead. there is no problem doing that.
Old Jul 13, 2005 | 08:28 PM
Default Re: (gsrious)
stroke is also the same?
Old Jul 13, 2005 | 11:55 PM
WickedSol's Avatar
Default Re: (slambedcivic)
stroke will be the same as the rotating assembly you install...the block housings are the same size...be sure to hone your cylinder walls...
Old Jul 14, 2005 | 12:01 AM
gsrious's Avatar
no no no... ls stroke is 89mm and gsr stroke is 87mm. that why i said you have to use gsr rods with a gsr crank or ls rods with an ls crank.
the piston the deck height on both are the same though.
Old Jul 14, 2005 | 12:54 AM
WickedSol's Avatar
eh? I was agreeing with you, GSRIOUS...if your installing a gsr rotating assembly into a ls block you will have a gsr stroke...if you throw a ls rotating assembly into a gsr block you'll have a ls stroke...
Old Jul 14, 2005 | 05:05 AM
Default Re: (SpdImge415)
cool guys, thats for simple answers to my simple question
HondaAddict91
Engine Machining & Assembly
Oct 9, 2016 06:37 PM
mrDFWmechanic
Apr 10, 2005 03:07 PM
EH2LS
Apr 29, 2004 08:24 AM
