Suspension & Brakes Theory, alignment, spring rates....
Which shocks should I go for?
Old Jul 13, 2005 | 09:54 AM
br0k3nmind's Avatar
Default Which shocks should I go for?
Hey peeps. I have a 1998 Civic EX and I'm looking to drop it real soon. Only thing I'm hesitating for is the brand of shocks. Considering I'll probably get Eibach Sportline Springs, and that the car will be going through winter, should I get KYB GR-2 shocks or Koni Red's? I talked to someone who told me the reason in getting Koni Red's is mostly for getting a stiff ride, while stiff isn't quite good for the winter. He said I'd be better off with KYB ($$ cheaper and does the job), but suggested me to ask over here. So that's what I'm doing. Hope to get an answer soon
Peace
Old Jul 13, 2005 | 10:00 AM
Dave The Flave's Avatar
Default Re: Which shocks should I go for? (br0k3nmind)
Alright, its your first post, so im not gonna flame you, but you need to post this in the suspension forum, youll get a lot more responses, and you wont get flamed by anyone. And people here at h-t are always looking out for you, and they'll always let you know loud and clear if you've made the slightest mistake.
Old Jul 13, 2005 | 10:01 AM
eg6sir-s's Avatar
koni yellows
Old Jul 13, 2005 | 10:03 AM
Tuesdaynightfever's Avatar
KYB AGX's.
Old Jul 13, 2005 | 10:07 AM
EK k kay's Avatar
Default Re: (Tuesdaynightfever)
KYB AGX are good at the price for street use
Old Jul 13, 2005 | 10:09 AM
br0k3nmind's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave The Flave &raquo;</TD></TR><TR><TD CLASS="quote">Alright, its your first post, so im not gonna flame you, but you need to post this in the suspension forum, youll get a lot more responses, and you wont get flamed by anyone. And people here at h-t are always looking out for you, and they'll always let you know loud and clear if you've made the slightest mistake.</TD></TR></TABLE>
Heh alright, I'll check myself out, thanks for the advice. Can someone transfer the thread in the other section or do I have to make a new one?
Old Jul 13, 2005 | 10:14 AM
DJ_SaNdOz's Avatar
Default Re: (br0k3nmind)
If you ever plan on doing any real performance driving, whether it's on a track or not, you would be better suited to steer away from GR2's or Tokiko Blue's (HP). For everyday driving, either of those ride very well w/ a nice set of springs, but they are too soft for really pushing the car to it's limits.
Old Jul 13, 2005 | 10:29 AM
br0k3nmind's Avatar
Default Re: (DJ_SaNdOz)
I've been told Tokiko is the suck. What big difference between Koni Red's and KYB GR-2 or AGX? And which performs better during winter?
Old Jul 13, 2005 | 07:58 PM
civic_tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by br0k3nmind &raquo;</TD></TR><TR><TD CLASS="quote">I've been told Tokiko is the suck. What big difference between Koni Red's and KYB GR-2 or AGX? And which performs better during winter?</TD></TR></TABLE>
u can go with the reds or agx and they are adjustable on the other hand u have gr-2 which is typical oem replacement. for winter i dont any them can handle slippery when wet.
Old Jul 14, 2005 | 12:47 PM
br0k3nmind's Avatar
Default Re: (civic_type_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r &raquo;</TD></TR><TR><TD CLASS="quote">for winter i dont think any of them can handle slippery when wet.</TD></TR></TABLE>
Yeah, I suppose every dropped suspension sucks for winter, but I don't feel like always taking it off or buying a beater. I'll just be driving more carefully.
Anyone else could lighten me up, help me make a choice?
Old Jul 14, 2005 | 01:12 PM
bad-monkey's Avatar
both are OEM replacement shocks, and i'd use neither in a lowered setup.
you should be looking at the koni yellows, KYB AGX, and Tokico Illumina for this particular application. they cost extra money, but they're the "right" part for the job and can handle the extra strain put on dampers when you lower a car.
I'd recommend the AGX as they're the cheapest, and suitable to your application.
Old Jul 14, 2005 | 02:04 PM
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">both are OEM replacement shocks, and i'd use neither in a lowered setup.
I'd recommend the AGX as they're the cheapest, and suitable to your application.</TD></TR></TABLE>
Exactly what I was going to say.
Old Jul 14, 2005 | 04:47 PM
br0k3nmind's Avatar
Alright, AGX seem more recommended by you guys, I'll take that in consideration. Another thing I was wondering, how do I know if I need a camber kit?
Modified by br0k3nmind at 7:44 PM 7/15/2005
Old Jul 15, 2005 | 06:44 PM
br0k3nmind's Avatar
Bump
Old Jul 15, 2005 | 08:00 PM
odds are, you wont need a camber kit, even if it looks like you do. Just make sure you get your car aligned asap after you lower it. Honda specs say that for even tire wear camber can't be any worse than -1 but i've seen a guy with -1.6 run fine with just an alignment.
Old Jul 16, 2005 | 10:40 AM
Just get your toe set to factory spec. You should be good. Also, after reading all the horror stories about camber kits recently, I'm almost scared to ever use one.
Old Jul 16, 2005 | 03:13 PM
runnin9z's Avatar
Koni has a kit out with there Reds and Eibach sport lines, they are made to work to gether and i think the shocks are specilly valved. WEll an way my friend has this kit on his 97 ex coupe and to mee ti seem liek the perfect drop and increase in handeling for the street.
http://www.tirerack.com/suspen...ode=S
This is the kit im talking about its avalible at tire rack
Old Jul 16, 2005 | 07:53 PM
br0k3nmind's Avatar
Default Re: (runnin9z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runnin9z &raquo;</TD></TR><TR><TD CLASS="quote">http://www.tirerack.com/suspen...ode=S</TD></TR></TABLE>
Thx for the reference, pretty good site! I'll make sure to check it out, and read the reviews.
Also, is the camber the same for a specific height reduction for every car or is it always different? If there's a specific height to reach the -1 or -1.6 camber, what would it be?
Old Jul 17, 2005 | 06:23 PM
br0k3nmind's Avatar
Anyone?
AngryFridge
Suspension & Brakes
Feb 5, 2012 01:58 PM
iNtoXicaTedSPOON
Jan 19, 2004 12:01 PM
GoLowDrew
Sep 30, 2003 03:36 PM
H23A1LUDE
Jul 22, 2003 09:28 PM
Integra21
Jul 15, 2002 10:23 AM
