Sqeaky front end noises ( 90 Accord )
It used to be just going up hills, but now all the time.
<U>Squeek 1</U>
Every turn I take I get a sqeaky noise...only when turning the sterring wheel. I can kinda 'feel' it too in the wheel.
<U>Squeek 2</U>
Any time the front is bouncing....so all the time. I think suspension bushings. Maybe shocks?...stock shock on Neuspeed Sport springs. They came with the car when I bought it. Car has 263k on it.
Any ideas? And again this is my 90 EX Sedan.
<U>Squeek 1</U>
<U>Squeek 2</U>
Same thing happened on mine, nice and smooth when going straight but a squeaky/scratchy sound when making turns. It turned out to be the wheel bearings, jack the front end up...put the car in neutral and turn the wheel with your hand....if you hear a grinding/sqeaky/scratchy noise its the bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 »</TD></TR><TR><TD CLASS="quote">Definitely need shocks. Is it a squeak or a clicking when you turn?</TD></TR></TABLE>
Definitely squeak. I'll look up some cheap KBY's of Tokico HP's. I know it's not axels too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97jellybean »</TD></TR><TR><TD CLASS="quote">check the power steering fluid. Usually when you are low you can really feel it in the wheel and makes the sound of like a whale when you turn (when it gets low).</TD></TR></TABLE>
I thought that could be it, wasn't sure though. I've never had PS before. It's due for an oil change so I'll have that check at the same time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2Phunk »</TD></TR><TR><TD CLASS="quote">Same thing happened on mine, nice and smooth when going straight but a squeaky/scratchy sound when making turns. It turned out to be the wheel bearings, jack the front end up...put the car in neutral and turn the wheel with your hand....if you hear a grinding/sqeaky/scratchy noise its the bearings. </TD></TR></TABLE>
I'll try this over the weekend. I'm not driving it everyday anymore and it's getting the oil change on monday or Tuesday.
Thanks guys.
Thanks guys.
if the squeak is coming from the steering wheel i would first lube the canceling cam //////
on the over the bumps squeak chk the inner sawy bar bushings before replacing shocks . .remove the ineer bushing and lube them
jhmman
Apr 15, 2019 06:43 AM
4tika4
Aug 15, 2016 09:10 PM
amej8
18
Jan 26, 2011 06:27 AM
92BlackSi
Suspension & Brakes
Jan 18, 2005 08:56 PM
