motor rebuilt.. how long ........
do you use ND oil?
i'm about to hit 500 miles on the motor. do i keep using the ND oil or do i switch to whatever oil i'm going to use?
thanks
thanks
@ 500 miles you should be ok to switch to synthetic, as long as your motor was properly tuned upon startup... (a/f ratio, timing, fuel pressure) to properly break-in a new motor would be to have it tuned on a dyno w/wideband, and run the motor hard, so that the piston rings will seat fast...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote"> i'm about to hit 500 miles on the motor. do i keep using the ND oil or do i switch to whatever oil i'm going to use?
thanks</TD></TR></TABLE>
You can go ahead and switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">do you use ND oil?
Pull all of your plugs and shine a flash light down into the cylinder. If you see oil on top of the pistons, do not switch yet. If they are dry, go ahead and switch to synthetic.
ITRBOY1433
Dec 14, 2008 04:37 PM
djdownfawl
Honda Civic (2001 - 2005)
13
Apr 18, 2008 02:38 PM
J.nguyen
Honda S2000
16
May 19, 2007 09:02 AM
BB4
Sep 11, 2006 02:29 PM
