ls chipped ecu?
ok i got a computer chip for my ls ecu and i wanna know if i just add that with dual valve springs is that safe ? will it harm my motor? also the stock redline is 7 grand and with the chip it can go up too 8500 grand? so im wonderin is just dual valve springs enough to take it that high ? or should i just get the valves and retainers also. and if i need the valves and retainers anyone know where i can get some for cheap but i want them to have performace and last until i swap out my motor ? i was thinkin rev hard valves and retainers are those any good? anyone heard any stories bout them or can give me some other ones i can use that are good and also wont break and last
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">On stock cams your not going to make much more power over 7300 rpms.</TD></TR></TABLE>
the motor will have power falling off fast past 7300
no the ls head has street/strip stage 2 cams , stage 2 port n polish and daul valve springs and aem cam gears ? so what u think i should be shifting at once i throw in the chipped skunk2 chip?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorek8 »</TD></TR><TR><TD CLASS="quote">so what u think i should be shifting at once i throw in the chipped skunk2 chip?</TD></TR></TABLE>
I hope the bottom end isnt stock...
Put it on the dyno and see where the powerband is
ya it will be stock ? its just until i finish my other motor but it will be a built ls head wit a stock bottom end . but the built ls head with dc 4-1 headers,catback exhuast, and short ram intake? what u guys think bout that ? with a chipped ecu for a ls how far should i bring it up too? with just dual valves?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorek8 »</TD></TR><TR><TD CLASS="quote">ya it will be stock ? </TD></TR></TABLE>
Anything over 7800-8000 on a stock B18A/B bottom end and you're asking for trouble.
You will need:
1 ARP rod bolts installed and the big end of rods resized
2 A good balance on the rotating assembly
3 New bearings (tri-metal) would also add to the long term reliability
4 VTEC oil and water pumps would be nice also
Many have run with less and had success, but this sounds like the A-typical setup for building a reliable NA bottom end for revving the LS non VTEC engine to around 8K. Some on a budget will go with #1 only. Some will rightly add #2, and while you have everything apart, do #3, and if you are revving to 8K often go with #4.
Sorry, I have to go #2 now, good luck...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorek8 »</TD></TR><TR><TD CLASS="quote">what would i have to do to the bottom end to make it handle at least 8 grand shifts?</TD></TR></TABLE>
Why do you want to rev that high? Will the motor even be making power up there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorek8 »</TD></TR><TR><TD CLASS="quote">ya it will make power up there to 8500 rpm</TD></TR></TABLE>
Do you have dyno charts for motors running the same head/block/cams?
Cyphear
17
Feb 20, 2005 06:18 PM
