Battary or Starter?
Old Jul 12, 2005 | 07:37 PM
5lugSlug's Avatar
Default battery or Starter?
My car kinda died today... the accessories would turn on but the engine wouldnt turn over.
I got a jump and then the engine would turn over..
When I would switch between High Beems & Low Beems the accessories would pause (like it would kinda reset, the cd would restart itself like it skipped or something.)
Is this a problem with the starter or the battery?
Old Jul 12, 2005 | 07:43 PM
Kyles ej1's Avatar
Default Re: Battary or Starter? (waterboy)
battery...if it was the starter it wouldnt start if u jumped it
lsvtecracer's Avatar
Well, if you jump it and it start then it sounds like the battery to me. I would get the battery tested.
Old Jul 12, 2005 | 07:45 PM
5lugSlug's Avatar
cuz my step dad said that it sounded like the starter had a loose wire, but i was thinkin like you guys because if the car would start with a jump then it would be the battery..
Old Jul 12, 2005 | 08:00 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (waterboy)
well if the accessories' power was fluctuating, then you can rule out the starter.
Old Jul 12, 2005 | 08:55 PM
JDM-EJ1's Avatar
Default Re: Battary or Starter? (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">battery...if it was the starter it wouldnt start if u jumped it</TD></TR></TABLE>
Exactly. If it was the starter, it wouldn't even start.
Old Jul 12, 2005 | 09:02 PM
xEnderx's Avatar
Default Re: Battary or Starter? (JDM-EJ1)
If the solenoid clicks once then its a crap *** battery. Even if it reads 12 volts static then you can be dropping 7 volts (or more!!!0 during cranking.....which will not turn the starter over. Had the same thing happen to me earlier today as a matter of fact. Just fill the water up and then stick it on a charger for a couple of hours.
Old Jul 13, 2005 | 06:28 AM
5lugSlug's Avatar
i just baught a new battery...
$90 for a optima (not a bad deal)...better keep stay alive for awhile
Old Jul 13, 2005 | 06:41 AM
bahraini civic's Avatar
it could be ur alternator..
pgpunkguy
Jan 22, 2008 11:29 AM
go2sleep
May 6, 2007 08:42 PM
Integra_drk
Dec 27, 2006 10:19 AM
DAYUIZ
Jan 20, 2004 03:03 PM
mingchi69
Jul 14, 2003 06:14 PM
