Oil Pan leak at drain plug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">You can also try using some of the ligued silicone gasket maker around the washers as well.</TD></TR></TABLE>
It's not needed whe using new crush washers. Hell, I've been on the same crush washer for the past 3 oil changes, no leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai »</TD></TR><TR><TD CLASS="quote">My oil leaks at the drain plug even with new crush washers. What have you guys done to prevent this - besides new oil pan?</TD></TR></TABLE>
Are you tightening the bolt to the proper torque rating?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai »</TD></TR><TR><TD CLASS="quote">hehe, yea, I know how to tighten a bolt. I've done more complicated things. </TD></TR></TABLE>
I guess the question should be... did you use a torque wrench when you put the drain plug back in? if so, what did you torque it to?
I'm not saying you don't know how to. But, maybe you are leaving it a little loose. So, when the heat expands and contracts the metal, it'll leak.
Try a new bolt ? Pan threads are stripped ? Also it may not make a difference but look real close at each side of a new (Honda) crush washer. One side has a rougher finish. I always put that side out.
Modified by alotawatts at 8:58 PM 7/12/2005
turboteg90's
17
Aug 10, 2008 06:59 PM
