Help! Fan won't turn on!
Old Jul 12, 2005 | 11:58 AM
JDMSi92's Avatar
Default Help! Fan won't turn on!
The fan in my car won't turn on for some reason and is causing my temp gauge to rise a little above half in traffic. Once I am moving it quickly cools down. I have replaced the thermo switch, fan relay, and tested the fan and everything is fine. What else could it be? Has anyone had any problems hooking it up for constant power? Please give me some advice the wheather is getting hotter!!
Old Jul 12, 2005 | 04:53 PM
honda_joe's Avatar
Default Re: Help! Fan won't turn on! (JDMSi92)
Did you check the fuse (under the hood)?
Simple things first..
Old Jul 12, 2005 | 04:56 PM
PrettyLude's Avatar
first check the fans, to see if its even getting power and go from there
Old Jul 12, 2005 | 08:04 PM
JDMSi92's Avatar
Default Re: (PrettyLude)
I checked the fan and it works fine, I checked the fuses and they are all good. I can't seem to narrow down what it is.
What is the best way to wire it to be on always and is there any downfall to this?
Old Jul 12, 2005 | 08:14 PM
h2392si's Avatar
Default Re: (JDMSi92)
change your radiator cap. i jus did a thread kind of just like this and i just got a new cap and it stopped overheating!! try it, only cost me 8.61 at kragen. peace.
Old Jul 13, 2005 | 05:36 AM
TurboCoop's Avatar
Default Re: (h2392si)
wire it to a switch
Old Jul 13, 2005 | 09:09 AM
PrettyLude's Avatar
wire it directly using a 5 pin relay to run costantly instead of running it to a switch, to where it switches on when key is on
Old Jul 13, 2005 | 12:27 PM
TurboCoop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">wire it directly using a 5 pin relay to run costantly instead of running it to a switch, to where it switches on when key is on</TD></TR></TABLE>Thats what I meant
Old Jul 13, 2005 | 06:41 PM
JDMSi92's Avatar
Default Re: (TurboCoop)
I did replace the cap too that was my first over heating problem....Do you guys have specs on the relays I need I think I saw a thread about this once before but I can't seem to find it now.
Wytas
Oct 16, 2017 01:44 PM
felipe69
Aug 27, 2009 05:13 PM
90civichbsi
Mar 29, 2009 03:01 PM
Eglifestyle
10
Mar 23, 2008 12:08 PM
RonP
Jun 3, 2003 06:59 AM
