Cel- No codes
Old Jul 12, 2005 | 11:12 AM
93si-hybrid's Avatar
Default Cel- No codes
hi i have a 93 si hatch with a 94 b18c1 and my cel is on. When i turn my key to on the light doesn't come on, but when i start it it comes on. When i try to check the codes nothing happens. Any help would be great. Thanks
Old Jul 12, 2005 | 11:22 AM
SpeedFreak77's Avatar
Default Re: Cel- No codes (93si-hybrid)
When checking the codes does the light just stay on after you put the jumper in? If so you need a new ecu.
Old Jul 12, 2005 | 11:35 AM
JimBlake's Avatar
Default Re: Cel- No codes (SpeedFreak77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 &raquo;</TD></TR><TR><TD CLASS="quote">When checking the codes does the light just stay on after you put the jumper in? If so you need a new ecu.</TD></TR></TABLE>NO! It's supposed to stay lit constantly (with the jumper in place) if there's no error codes stored. Code zero (bad ECM) is when it stays OFF when you put in the jumper.
Check the wiring for the CEL, maybe it's not hooked up correctly with '93 car & '94 ECM? Also check whether the plug you jumper is connected correctly to the ECM. Don't be so quick to say the ECM is bad.
Old Jul 12, 2005 | 11:46 AM
when i turn on my key there is no engine light. When i start my car the light comes on. i turn my key to the on position and it just stays lit when i jump it. I will check my wiring later. And it's a obd-1 p72 ecm. I will try my p28 to see if that works.
Thanks
Old Jul 12, 2005 | 01:30 PM
JimBlake's Avatar
Default Re: (93si-hybrid)
Maybe this can help you check out your wiring...
CEL is always powered from the main relay. The ground side of the bulb circuit is switched by ECU pin A13.
ECU pin D4 goes to the SCS connector. When you jumper that plug, what you're really doing is connecting D4 to ground.
Old Jul 20, 2005 | 08:21 PM
Default Re: Cel- No codes (JimBlake)
When i turn the key to on, and jump there is no light now.
Old Jul 21, 2005 | 05:01 AM
JimBlake's Avatar
What did you find when you checked your wiring? Does the CEL have it's power? Does it come on for it's bulb-check or not at all? Continuity in the wire from CEL to ECU A13?
turbo sol
Apr 2, 2009 05:31 PM
stealth89hatch
Aug 15, 2005 04:48 PM
game over
Feb 19, 2005 06:15 PM
BlkGSR
Jun 18, 2003 07:11 PM
Dragger817
Aug 18, 2002 12:46 PM
