Removing "type R plate"
Old Jul 11, 2005 | 08:54 PM
SamC's Avatar
Default Removing "type R plate"
How do I remove the 2 rings on the back without breaking the "pins"? Any tips? Thanks.
Old Jul 11, 2005 | 09:09 PM
yellow blur's Avatar
Default Re: Removing "type R plate" (SamC)
Is that on the arm rest?
Those are the same ones that hold the emblem on the bumper. I just ended up breaking mine off. If you have more patience, I believe that you can just break the little plates off without breaking off the whole peg.
Old Jul 11, 2005 | 09:13 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SamC &raquo;</TD></TR><TR><TD CLASS="quote">How do I remove the 2 rings on the back without breaking the "pins"? Any tips? Thanks.</TD></TR></TABLE>
The words "dremel" and grinder come to mind.
Could try Vasaline, baby oil and/or... oh damn, what's that water soluable lubricant? (just kidding)
Look, this should be pretty simple!
What would YOU think your options are?
SamC's Avatar
Default Re: Removing "type R plate" (yellow blur)
Yea. that's the back of the arm rest. I couldn't get the ring/plates off.
Old Jul 11, 2005 | 09:18 PM
Naruto's Avatar
those look similar to the ring plates that held the floor carpet onto my buddie's CRX's side panel thing ( dunno what it's called ) that sits on the door jam. I used a flat head screw driver and VERY carefully removed them to seperate it. But....not sure if that's going to work for that. You can give it a try though. But again...be very careful.
Old Jul 11, 2005 | 10:37 PM
typeR#0427's Avatar
Default Re: Removing "type R plate" (psychoticmindset)
There really isn't a good way that I know of to get that off.
Did you buy an armrest elimantor? If so, and you didn't buy the cover for the bolts, you will be cutting anyway.
I had to carefully cut around the bottom of the rings, because they are crimped on.
So yes dremel, and razor blade is your friend
Old Jul 12, 2005 | 06:24 AM
1GreyTeg's Avatar
what's all that dirt and rust?
I just pulled mine straight off. The crimped clips both broke but it came off pretty cleanly. But I don't think I'd suggest this method since I think I got lucky and I was just pulling it off before the car went to the wrecking yard.
Old Jul 12, 2005 | 07:17 AM
Rene M's Avatar
Default Re: Removing "type R plate" (1GreyTeg)
I just did this last week...
Use a pair of needle nose and grab only the clip and rotate the clip on the plastic shaft and it will thread the plastic shaft and come off with out breaking the pins.
To re install just push them back on.
Old Jul 12, 2005 | 09:02 AM
SamC's Avatar
Default Re: Removing "type R plate" (Rene M)
Thanks Rene, I was turning the plate but it was coming off. Maybe I'll just need to do it longer. Thanks.
Old Jul 12, 2005 | 12:29 PM
Rene M's Avatar
Rotate it at an angle not straight and carefulley pull out while you do it and you will see it start to thread up the shaft. Be gentle or it will cut throught the shaft.
Old Jul 12, 2005 | 07:50 PM
PY 01-0972's Avatar
i had alot of fun with this too. needle nose and patience is key and a small flat head screwdriver and slowly with the needle nose back and forth it will come off. get new clips for the reinstall.
Old Jul 12, 2005 | 09:10 PM
SamC's Avatar
Default Re: (my si is bluer than yours)
After 45 mins of frustration with small flat screw driver and needle pryer. I finally got it off. Thanks guys.
B19CivicHB
Jul 3, 2009 07:49 PM
siriussr
Northwest
Apr 22, 2008 12:14 PM
Grip-1EM
19
May 23, 2007 04:02 AM
matttegra
Mar 11, 2005 10:57 AM
silver_nteg
Nov 15, 2003 06:27 PM
