ls/vtec main bearing have question
Old Jul 11, 2005 | 04:19 PM
jpangeles's Avatar
Default ls/vtec main bearing have question
i just bought a ls long block from hmotorsonline.com and drop in my crx with gsr head...after two months i decided to build my bottom block wiht ctr oil pump, arp rod bolt and some low compression piston...probably the tolal milleage on the engine is 40,XXX....my question is that wat size is the meain bearing should i use...it's ok if i use the standard one because i just bought a King bearing?
dstappity
Mar 7, 2011 11:21 AM
blackcrx16
Oct 15, 2007 06:45 AM
migs
10
Jul 15, 2005 07:40 PM
