EG suspension into EK
From what I've heard the front bolts right up.
How is the rear done?
https://honda-tech.com/zerothread?id=1178414
Someone mentioned in the thread above that you need to "shim out the rear shock between shock and LCA". Is this as simple as putting some washers in? or??
Anyone done this who can fill me in?
TIA
TIA
the arms no.
the shocks yes.
the only difference between EK and EG/DC2 shocks is that the EK's lower mount is a little narrower where it fastens to the lower arm. slap in two washers and they work fine.
**edit** by arms, I mean the lower control arms (LCAs) the trailing arms work on both.
the shocks yes.
BrianFreels
May 4, 2009 01:36 PM
vizsual00
24
May 26, 2004 10:09 PM
