tps??
Hey im getting code 7 which i beleive to be tps, how in world do you set it so that it reads right, my car is idling funny, and boggs like hell, slow as ****.
by the way i have a b16a swap in a ef.
thanx
thanx
it may be faulty but you can check it...
you can set the TPS so it shows 0.5v at closed throttle,
do this by measure tthe voltage on the signal wire (not the 5v one)
by undoing the screws that hold it in and moving it the tps signal should change...
do you have a shop manual?
hth,
t..
hth,
t..
no id ont really have a manual, i guess ill just have to play with it, until i get it right. WHat happen was i got the tps off my single cam, because it the dohc tps came broke off as they often do. I screwed on the tps, but i guess its not set where it should be, ill try the method you supplied, thanx for your info.
peace,
peace,
CRX A4
Jun 14, 2003 09:43 AM
