Lightweight flywheel = new tranny noises?
Old Jul 11, 2005 | 12:44 PM
Pompiuses's Avatar
Default Lightweight flywheel = new tranny noises?
A while back ago I installed a aluminum flywheel on my R. This flywheel failed, as the flywheel rim almost broke loose, which again caused the flywheel to become unbalanced/distorted. I hope that didn't do any damange to the gearbox. I replaced this flywheel with a one piece chromoly flywheel.
I remember after driving with the alu flywheel for a while i noticed a sound comming from my gearbox which very much resemble a bad input shaft bearing. When I put the car in neutral and rev it, I can clearly hear a noise from the tranny. When I push the clutch in, the noise goes away. This noise is still there with the chromoly flywheel.
Is this normal when using lightweight flywheels, or did the alu flywheel cause my input shaft bearing to go bad?
Old Jul 11, 2005 | 12:49 PM
Tweakmeister's Avatar
Default Re: Lightweight flywheel = new tranny noises? (Pompiuses)
I can hear a similar noise - haven't cracked open the tranny to look.
Old Jul 12, 2005 | 02:42 AM
Pompiuses's Avatar
Default Re: Lightweight flywheel = new tranny noises? (Tweakmeister)
Anyone else with a lightweight flywheel here who care to comment?
Old Jul 12, 2005 | 04:32 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else with a lightweight flywheel here who care to comment?</TD></TR></TABLE>
My tranny is silent with a Fidanza flywheel.
Old Jul 12, 2005 | 05:08 AM
mehdiR's Avatar
No noise from my spoon flywheel area, maybe its your release bearing,
describe the noise if you can please.
Old Jul 12, 2005 | 05:15 AM
Pompiuses's Avatar
Default Re: Lightweight flywheel = new tranny noises? (mehdiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mehdiR &raquo;</TD></TR><TR><TD CLASS="quote">No noise from my spoon flywheel area, maybe its your release bearing,
describe the noise if you can please.</TD></TR></TABLE>
It definatley not my release bearing since the noise goes away when I press the clutch pedal down, and not vice versa. It's also brand new along with my clutch. It's either my input shaft bearing or a noisy flywheel.
I've been told that chromoly flywheels in particular transmits more noise than other flywheels. A friend of mine also have the Spoon chromoly flywheel, and he told me his tranny became a bit more noisy than with the stock flywheel. I dunno what to think.....
Old Jul 12, 2005 | 05:40 AM
ultimatehonda's Avatar
I have the same exact noise!!!! I have even attemped to replace the input shaft bearing with a new one and noise is still there....I really hope its the flywheel. I have a ACT prolite flywheel. The noise only comes when there is a certain load, like the A/C. Its weird.
Old May 11, 2006 | 02:48 AM
aj008's Avatar
Rather than starting a new thread, I thought I'd add to this old one...
I've been experiencing this same exact noise on my car, took it to a transmision specialist, thinking it was input shaft bearing. They diagnosed the noise by testdriving the car and believed it to be coming from the clutch. I had the clutch replaced soon after with an oem clutch kit, flywheel resurfaced. Got the car back and the noise has all but gone away, I still have this noise but is alot less noticeable than before the new clutch and flywheel resurfacing.
Previous clutch was a Spoon 3 puck, and im guessing the flywheel is Spoon as well (came with the teg when I bought it). As much as I liked how the Spoon racing clutch bites, it was a nuisance to drive to work daily in traffic.
Anyone else experiencing this sort of noise with lightwheight flywheels?
Old May 11, 2006 | 05:57 AM
43!'s Avatar
43!
Default Re: Lightweight flywheel = new tranny noises? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
My tranny was silent with a Fidanza flywheel. </TD></TR></TABLE>
Old May 12, 2006 | 08:05 AM
realis9's Avatar
Default Re: Lightweight flywheel = new tranny noises? (43!)
Does anyone notice when they put on a new lightweight flywheel 7.5 lbs the car vibrates a little more and slows down a lot quicker?
Old May 12, 2006 | 08:08 AM
RTW DC2R's Avatar
Default Re: Lightweight flywheel = new tranny noises? (realis9)
slows down quicker, yes
vibrates more, no
weird noises, no
Old May 12, 2006 | 08:24 AM
realis9's Avatar
Default Re: Lightweight flywheel = new tranny noises? (clip the apex)
i whenever i press the clutch pedal to the floor i feel some vibration. It comes and goes. What do you thing it could be? I just got the clutch and flywheel installed. Only have 18 miles on it now. I took it for a drive today and now i feel the vibration.
Old May 12, 2006 | 08:31 AM
RTW DC2R's Avatar
Did you replace the throwout bearing when you installed the clutch?
Old May 12, 2006 | 08:43 AM
realis9's Avatar
Default Re: (clip the apex)
Everything got replaced and greased. All brand new parts from the clutch kit.
patrickstar
Aug 11, 2009 05:25 PM
unknown0001
Dec 14, 2006 12:27 PM
dannydos
Oct 11, 2005 04:52 PM
AlxSiR7
Sep 21, 2004 02:32 PM
