findanza flywheel making noise
Old Oct 10, 2005 | 03:52 PM
dannydos's Avatar
Default findanza flywheel making noise
hey what's up HTer's..... well 3 weeks ago i noticed that my transmission was making a funny noise.... and my motor wouldn't start for like 6 sec....then it would finally start.... so i took apart the starter and i noticed that their is a lot of play with the flywheel....my ? is should i just buy a new flywheel or get this one fixed ( the flywheel is a 2 pcs ) i have a new clutch that is going to be installed shortly... has this happened to anybody else.... should i stay away from findanza flywheel...I'm looking at the ACT Flywheel as a replacement but their is a big price difference.
Modified by dannydos at 8:54 PM 10/11/2005
Old Oct 10, 2005 | 04:01 PM
doublejz's Avatar
Default Re: findanza flywheel making noise (dannydos)
you sure the flywheel bolts just arent loose?
Old Oct 10, 2005 | 04:10 PM
dannydos's Avatar
Default Re: findanza flywheel making noise (doublejz)
i'm pretty sure .... the outter teeths are the only thing that moves..
Old Oct 11, 2005 | 01:07 PM
dannydos's Avatar
bump
Old Oct 11, 2005 | 03:12 PM
gsrious's Avatar
the ring gear(gear on flywheel where the starter turns onto) might have separated from the actual flywheel due to expansion rate in meatals.
**however... do what you must.
Old Oct 11, 2005 | 03:15 PM
Chiovnidca's Avatar
I'd quit driving it, and pull the flywheel out to inspect. You may be able to repair it if there isn't too much damage.
Old Oct 11, 2005 | 03:52 PM
rainforest's Avatar
Default Re: findanza flywheel making noise (Chiovnidca)
sounds like the bolts are loose. you shouldent have any play on a peice of solid aluminum.
Old Oct 11, 2005 | 04:33 PM
dannydos's Avatar
Default Re: findanza flywheel making noise (rainforest)
thanks for the replies guys.... i'm done with findanza.... well 2 pcs flywheels altogether...
Old Oct 11, 2005 | 04:40 PM
NJIN BUILDR's Avatar
The ring gear is press fit to the flywheel.Sounds like it is spinning on the flywheel.
Get it fixed before it breaks and really f's things up.
Glenn
Old Oct 11, 2005 | 04:52 PM
dannydos's Avatar
Default Re: findanza flywheel making noise (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The ring gear is press fit to the flywheel.Sounds like it is spinning on the flywheel.
Glenn</TD></TR></TABLE>
is this design the same with all flywheels
01LUDEebp
Sep 19, 2016 11:14 AM
wakaranai
17
Sep 14, 2016 07:02 PM
Pompiuses
May 12, 2006 08:43 AM
AlxSiR7
Sep 21, 2004 02:32 PM
lilcasino
Aug 4, 2002 08:25 AM
