1994 civic burning oil help!!
Old Jul 11, 2005 | 05:12 AM
pballsqu*id69's Avatar
Default 1994 civic burning oil help!!
Hey guys i have a 1994 civic ex coupe and it is burnin oil alot and fast........it got alot of blue smoke comin out of exhaust and withiin a month i was completely out of oil......ne way to look for things or fix will be greatly appreciated.......
Derek
Old Jul 11, 2005 | 05:51 AM
One2chi's Avatar
Default Re: 1994 civic burning oil help!! (pballsqu*id69)
head gasket. if youre handy.... its not THAT big of job. if youre not, it can be kinda costly. check your coolant to see it it looks shitty (brown and yucky) its probobly your head gasket....
bad pcv valve. if oil is traveling up the lines to your intake, you could be burnign oil that way. check for oil in yoru air filter.
piston rings...excessive blowby could cause you to burn oil...if this is the case, consider buying a new engine, unless you want to pay to have this one rebuilt.
those are the few biggies i can think of off the top of my head....
Old Jul 11, 2005 | 06:01 AM
i have new head gasket and pcv valve is there nethan else to check for?
Old Jul 11, 2005 | 06:12 AM
One2chi's Avatar
tyr a compression/leak down test.....that COULD tell you if yoru rings are shot...ill think on it...give me 15 more mins
Old Jul 11, 2005 | 06:21 AM
did a compression test and it is perfect......so does that mean it aint the pistons......?
Old Jul 11, 2005 | 06:33 AM
One2chi's Avatar
Default Re: (One2chi)
cant think of anythign else....except maybe they(you) fucked up the gasket puttign it on.... or mayeb a tiny crack in your block...b.ut my money is on some rings that are fucked up.
Old Jul 11, 2005 | 07:39 AM
bosco500's Avatar
Default Re: (pballsqu*id69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pballsqu*id69 &raquo;</TD></TR><TR><TD CLASS="quote">did a compression test and it is perfect......so does that mean it aint the pistons......?</TD></TR></TABLE>
You need to do a leakdown test. Your valve seals could be shot.
Also, a compression test wont tell you if your oil ring is bad.
Old Jul 11, 2005 | 08:10 AM
One2chi's Avatar
Default Re: (bosco500)
bosco is right, i meant leakdown test, and valve seals is a damn good idea.
Old Jul 11, 2005 | 10:49 AM
freakasis's Avatar
hook an air compressor up to the compression tester fitting, and put in yer spark plug hole....position the cam so that the valves are closed and see if you hear air leaking out. if you do follow the sound to see where its comming from. do this for each cylinder.
Pothole987
Honda Civic (2001 - 2005)
Oct 2, 2011 04:38 PM
mr2passat801
Aug 15, 2010 08:16 AM
Kammy_Teg
Oct 11, 2008 02:14 PM
90datech
Mar 29, 2007 12:42 PM
BigC-ivic
Aug 27, 2005 07:53 AM
