how much oil to put in jdm d15b
Old Jul 10, 2005 | 05:13 PM
byronl's Avatar
Default how much oil to put in jdm d15b
hey guys, well i found out that the mechanic place i went to change my oil overfilled it almost 1 quart. When they finished, my oil light was on and I went back to place and they added more. Anyways I'm gonna do my own oil change on my own and was wondering if 3.5 quarts is good? thx.
Old Jul 10, 2005 | 05:51 PM
Jim Truett's Avatar
Default Re: how much oil to put in jdm d15b (byronl)
3.5 quarts is where you want to start, but don't simply use that number to indicate if it is full. The holes on your dipstick are the level indicators. The upper hole is full, the lower hole is 1 quart low.
Old Jul 10, 2005 | 06:06 PM
97civicsedan's Avatar
B A N N E D
Put 3.5 quarts and check the dipstick to see if it is in the safe area. Its when the oil level is between the holes. If its not just add it and check.
Old Jul 10, 2005 | 08:19 PM
Deemeetree's Avatar
Electrician
That's why engines are equipped with dipsticks, to monitor the level of the fluid and tell when to stop, and when not to.
Old Jul 10, 2005 | 08:22 PM
integraXTC's Avatar
Default Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">That's why engines are equipped with dipsticks, to monitor the level of the fluid and tell when to stop, and when not to.</TD></TR></TABLE>
lol, yup. That simple. Anyways, didn't you say they overfilled it and then added more?
Old Jul 10, 2005 | 09:29 PM
EK k kay's Avatar
Default Re: (integraXTC)
On my D series I pour in 3.5qts, run it for a while let it settle and check it again later to see if I need more. Usually I am right at the second hole.
Old Jul 10, 2005 | 09:48 PM
RATED EG's Avatar
Default Re: (chowmien)
look at the dipstick
Old Jul 10, 2005 | 10:45 PM
byronl's Avatar
Default Re: (RATED EG)
the mechanics that did the oil change put in oil and when they finished my oil light came on. I told them about it and they added more oil, i later found out that they passed the second hole on the dipstick to about almost an extra quart worth of oil.
bopbop93030
May 13, 2008 04:30 PM
cilvia
Jan 10, 2008 12:38 AM
EK_B
Oct 28, 2007 02:39 PM
Vouthanack
Jul 30, 2004 11:18 AM
todaspecsi
46
Apr 29, 2004 05:08 PM
