obd1 distributor to obd2 harness
1.This is what it looks like. The one piece connector on the left is the OBD2 from my d16 dizzy. The two connectors on the right are from my OBD1 harness I got with the motor.
2.This is a pic of the OBD2 connector I cut from my d16 dizzy. This connector plugs into your wiring harness.Cut your dizzy with as much room on the wires as possible.
3.These are the two connectors I cut from the OBD1 wiring harness I got with the engine. They will plug up to your new OBD1 dizzy you now have to go buy.
4. These are the connections. I crimped them, but soldering them would be better. The colors match up perfectly. Mine were a liitle faded so it threw me off a little, but you realize which ones they hook up to. ie...white to white.....Goto hondaswap and look at the "clicking noise" post I started and you wrote in. I posted the color chart there just in case.
great thanks to JOsh for this info..
Modified by ekb16 at 6:20 PM 7/10/2005
Guest
Posts: n/a
swap internals. I just swapped the internals from a b7 dist to a y7 dist and everything bolts right in no mods were nessasary. Looks like a stock dist but now you can run a y5,y7 or y8 in your eg with no problems or just head if you want. Took me 5 minutes to do it. It'll work the other way no problems for if you want to run a z6 or any obd1 dist in your in your EK. All OBD1 and OBD2 sohc dist's are the same internally.
aw1234dude
Sep 28, 2003 02:56 PM
