Bad input shaft bearing or throwout bearing ?
Old Jul 10, 2005 | 09:20 AM
Problemo's Avatar
Default Bad input shaft bearing or throwout bearing ?
A quick one for all of you in the know, I have ready many conflicting sources of information on this one but need a definitive answer. While my car is running and is in neutral with my foot OFF the clutch I hear a noise which sounds like a squealing belt.
When I put my foot on the clutch slightly, the noise goes away.
My question is, does this sound like the input shaft bearing, or the throw out bearing. If anyone has a definitive answer I would be most greatful. The reason I ask is I have just had a new exedy clutch installed, with new throwout bearing etc.
Like I say I have searched, but there are many contradicting sources out there. Just wanted a definitive answer.
Cheers folks,
- Prob
Old Jul 10, 2005 | 12:49 PM
DeadVet's Avatar
Default Re: Bad input shaft bearing or throwout bearing ? (Problemo)
Throwout bearing for sure....
Old Jul 11, 2005 | 03:54 AM
simon98h22's Avatar
Default Re: Bad input shaft bearing or throwout bearing ? (1TurboHatch)
I had the exact same thing.
About 5 weeks after installing my Exedy Stage 1 clutch, my release bearing (new one that came with the clutch) went and needed to be replaced. Sometimes you get duds in life .....
Old Jul 11, 2005 | 08:51 AM
six_speed's Avatar
constant noise all the time (clutch engage, clutch pedal not depress)= input shaft bearing
noise only when clutch is disengage(pedal depress)= throw out bearing
TOO MUCH TORQUE
Oct 3, 2015 10:20 PM
AddictedToBoost
Feb 25, 2012 07:58 PM
hcs1jimmy
Apr 19, 2011 04:12 PM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
pa2play
Jul 28, 2005 09:42 AM
