When all else fails, how do I get my axle out?!?!
Old Jul 10, 2005 | 08:42 AM
Boosthead's Avatar
Default When all else fails, how do I get my axle out?!?!
I am retying to remove my passenger side axle to replace it. I have tried prying, jiggling, yanking, nothing is working. I thought I could use a punc and knock it out from the drivers side but there is a metal rod across the middle of the hole which prevents me from doing this.
Is there any other method that I am missing??
Old Jul 10, 2005 | 08:53 AM
rmcdaniels's Avatar
I got mine out with a combination of prying and wiggling, emphasis on the prying.
Old Jul 10, 2005 | 08:54 AM
Boosthead's Avatar
Default Re: (rmcdaniels)
Thanks. In the past, I havent had any issues with axles but this one is being super stubborn. Guess I just need a lot more patience and a little more finesse.
Old Jul 10, 2005 | 09:06 AM
B6tPoweredMx3's Avatar
Default Re: (Boosthead)
You need a Big ******* pry bar.
Emphasis on big
Usually i just wedge mine between the shaft near the transmission and pry and it usually pops rigth out.
Old Jul 10, 2005 | 09:36 AM
Crazydave's Avatar
Default Re: (B6tPoweredMx3)
get pry bar
stick it between the transmission and the inner joint
give it a quick hard jolt,
it should come right out
Old Jul 10, 2005 | 10:24 AM
Boosthead's Avatar
Default Re: (Crazydave)
I'm still working at it. I have tried brute force. The problem is that my 24" pry bar wont fit at the right angle between the axle/tranny because of the subframe (i think that's what it was in the way) so I am using the smaller pry bars. I've done about a dozen axles and this wont seem to come out by brute force or finesse. I'll keep at it. Thanks guys.
Old Jul 10, 2005 | 10:32 AM
Si Shane's Avatar
i used a small 12-16" crowbar. I stuck the long straight surface inbetween the axel and the tranny, and i was able to prop it on the tranny and just pull. I did by best to try and pull it evenly (pull on one side, then pull on the other). I also ended up hitting the bar with a sledge hammer, but what finally did it was the kind of pull that could have knocked the car off jackstands
as your pulling on it just keep thinking to yourself, "its not as bad as the shift linkage."
flaxx0r
28
Dec 29, 2008 07:15 AM
bara6075
Jul 14, 2007 11:03 PM
Boosthead
Jul 12, 2005 12:57 PM
ericlee303
Mar 1, 2004 11:57 AM
Doogie Howser
Sep 5, 2002 06:44 PM
