Possible to adjust automatic transmission shift points?
Old Jul 10, 2005 | 12:32 AM
chris89's Avatar
Default Possible to adjust automatic transmission shift points?
My friend has a 95' Civic EX with the 1.6 VTEC and his engine will rev to 7200RPM but every time he nails it, it'll only rev to 6200RPM and shift. It's an automatic transmission. Is it possible to get it to rev all the way to redline without buying anything?
Old Jul 10, 2005 | 12:39 AM
Kyles ej1's Avatar
Default Re: Possible to adjust automatic transmission shift points? (chris89)
drop it into gear and dont shift untill u want
btw u lose power at redline so theres no need to shift there
Old Jul 10, 2005 | 12:42 AM
chris89's Avatar
well the vtec will kick in a 5500rpm and in like 1 second it'll shift...the engine pulls to full engine power i think at 6500+ .....yes, i know about dropping it into the gear...Isn't that hard on the tranny? I was wondering if there was something that you can do to just let it rev to redline...Or atleast to 7000rpm
Old Jul 10, 2005 | 12:50 AM
Kyles ej1's Avatar
Default Re: (chris89)
a tranny swap
Old Jul 10, 2005 | 01:06 AM
chris89's Avatar
Know of any threads or tutorials on how to do the auto to manual swap?
Old Jul 10, 2005 | 04:43 AM
JDM-EJ1's Avatar
I'm doing one right now, you're going to need A LOT of parts.
Manual Transmission
Clutch/Flywheel
Shift Linkage (for whatever motor you have).
Manual Starter
Hydraulic Lines
Clutch Resovir
Slave/Master Cylindar
Pedal Assembly
Shifter
Shift ****
Console Peice
Shift Boot
Manual ECU
There is probably more, but I'm tired. That's the jist of it though.
DeviousJunez
Transmission & Drivetrain
Aug 19, 2016 07:32 PM
scottjo
Jul 31, 2010 02:29 PM
chris89
Jul 10, 2005 08:00 AM
slow99accord
May 14, 2003 09:54 PM
95civicracer
18
Feb 19, 2003 06:34 PM
