New Mugen low-temp fan switch!
I remember just a few days ago that someone stated that Mugen didn't have a low-temp fan switch like Spoon. Well, just today Kingmotorsports has them.
"A Mugen low-temp Fan Switch is now available for the Accord, Civic EG, Civic EK, Integra, and S2000. This switch activates the cooling fan at 80°C instead of the stock 93°C. More 2002 Mugen products will be added over the next few weeks. Stay tuned!"
I hope this isn't old news.
Are you sure those temps are correct ?, doesn't the Spoon switch kick in at 160 degrees F, that is much cooler than 80 degrees Celsius for the Mugen, the Mugen would be around 190 degrees F., only slightly cooler than stock. . I Wonder what one is better.
Joey
Joey
Joey
Joey
well 70 Celsius is abot 170 degrees F, I am sure I have seen Spoon suppliers advertise the spoon switch as 160 degrees F. Either way I just wonder what is the best temp setting, obviously running too cool is not good , or is running too hot. Anyone have an opinion on what temp would be best ?
Joey
[Modified by JSIR, 10:59 AM 2/16/2002]
Joey
The Spoon Japan website said it will reduce the coolant water temperature from 98 degree C to 80 degree C. If that the case, then it is the same as the Mugen one.
And the Mugen one is shown at $45, which is cheaper than the Spoon one. Now I wonder if it is OK to run Mugen switch with Spoon Thermostat?
Sorry, I couldn't resist...should not be any problem to mix and match though. Just get whichever makes you happy.
90Rexx
Aug 8, 2009 10:18 PM
underrated99si
Jul 29, 2002 08:56 PM
shi - whose getting antsy from peeps be talking bout c00lant switches and chitls
