Fluidyne Radiator and FAL Cooling Fan question, please help????????????
Old Jul 9, 2005 | 10:06 PM
bitchin camaro's Avatar
Default Fluidyne Radiator and FAL Cooling Fan question, please help????????????
okay, had some trouble with the valvetrain of my car, so after pulling the head and sending it out to get a new one...i've decided to pull the radiator and replace it with a full size Fluidyne. i decided that while i'm in there to replace the cooling fans. i am running A/C so i want the dual fans, but i've heard that they don't have brackets to hook up. is there a way, or has anyone done something to solve this problem?
possibility:
possibility:
could i get nuts and have them welded to the radiator, and then use the correct screw and use that as the bracket?
Old Jul 9, 2005 | 10:57 PM
mo0m0o619's Avatar
Default Re:
I'd like to know too since I have that setup and have never bothered to look into brackets to hold it.
Old Jul 9, 2005 | 11:10 PM
IN VTEC's Avatar
Default Re: Fluidyne Radiator and FAL Cooling Fan question, please help???????????? (bitchin camaro)
You can reuse the original main fan and only replace the AC condensor fan with a slimfan. They use a universal mount....aka the ziptie thingies. I'm sure you'll get a set when you get the fan.
Old Jul 10, 2005 | 07:31 AM
94integragsr's Avatar
Banned
Default Re: Fluidyne Radiator and FAL Cooling Fan question, please help???????????? (IN VTEC)
i just bought a koyo all aluminum radaitor and it came with brackets
Old Jul 10, 2005 | 11:53 AM
TurboTeG4's Avatar
Default Re: Fluidyne Radiator and FAL Cooling Fan question, please help???????????? (94integragsr)
I run the fluidyne with fal fans on my teg the full sized ones. You will have to obviously cut the fal fan for the lowers hose to fit properly, make a simple bracket to hold the fan to the radiator. There is multiple holes on the radiator and fan allowing many ideas to hold the two together. It is not a problem. Oh the fan comes with a bracket for the top, use that and drill holes in it to match the radiator and then use some pipe to make spacers between the radiator and the bracket then run a bolt through it.
Old Jul 10, 2005 | 01:37 PM
AllMotorDan's Avatar
im planning on getting the koyo raidiator soon
Old Jul 10, 2005 | 08:06 PM
Default Re: Fluidyne Radiator and FAL Cooling Fan question, please help???????????? (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">I run the fluidyne with fal fans on my teg the full sized ones. You will have to obviously cut the fal fan for the lowers hose to fit properly, make a simple bracket to hold the fan to the radiator. There is multiple holes on the radiator and fan allowing many ideas to hold the two together. It is not a problem. Oh the fan comes with a bracket for the top, use that and drill holes in it to match the radiator and then use some pipe to make spacers between the radiator and the bracket then run a bolt through it.</TD></TR></TABLE>
so, am i thinking this through too much? i haven't looked at the radiator yet, its still in the box in my living room, and the fans are on the way...
i just wanted to be prepared for what's to come, thanks for all the answers and support!!!
Old Jul 10, 2005 | 09:04 PM
TurboTeG4's Avatar
Yeah the left side will be mainly secure, dont need much to support the a/c side. I use 2 home made brackets, one for the bottom, where you see the diagnal peice with the 2 threaded holes on the radiator. Make an off set bracket for that and another bracket on the top of the radiator more towards the middle right on top. Make a bracket up there wont be hard, and use the existing holes on the radiator top for the rest.
GL
BongoBennie
Jan 10, 2017 06:29 PM
GRANT!
Oct 27, 2009 03:37 PM
almostboostedgsr
Jul 26, 2007 10:40 PM
EU BATT
Nov 22, 2002 08:23 PM
dilow
Mar 17, 2002 10:29 PM
