Fluidyne radiator and FAL fan install question
New User
I'm planning on buying a fluidyne radiator and FAL fan for my 95 civic and was wondering if the fan will hook up to radiator ok, or is there something special I'll have to do? Any info on this would be great. Thanks!
Re: Fluidyne radiator and FAL fan install question (dilow)
i'm not 100% sure, but i don't think this is true. i've read some post from people who run the fluidyne and the FAL fan and they said they had to do some modification to make the fan bolt properly to the radiator.
you may want to look @ C&R radiators. they flow just as good and they come with a slim fan. they also cost around $440 for radiator & fan.
give this guy a call:
Rob Cardona
C&R Racing
6950 Guion Road
Indianapolis, IN 46268
317-293-4100
317-293-4110 FAX
Rob Cardona
C&R Racing
6950 Guion Road
317-293-4100
317-293-4110 FAX
no, it wont bolt right up. The brackets that come with the fal fan need to be modified slightly, nothing difficult though. The top bracket needs the center cut out, so you basically have two pieces that are 2-3 inches long, and same with the bottom. At least thats how I did it. Hope this helps..
GRANT!
10-27-2009 03:37 PM
crxnatic
07-15-2008 02:19 PM
