Gsr block with ls bottom end.
Old Jul 9, 2005 | 03:53 PM
JDM MonopolyMan's Avatar
Default Gsr block with ls bottom end.
With an ls crank and rods in a stock gsr engine, what pistons would clear maybe p30's? Is the deck height the same or would I have to find some shorter rods? Can someone post the measurements of both rods? How much would it mess with my rod to stroke ratio? Your help is greatly appreciated.
Old Jul 9, 2005 | 04:02 PM
projectTeG's Avatar
you can use ls rods and crank in a gsr block , the deck heights are the same
Old Jul 9, 2005 | 04:06 PM
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">you can use ls rods and crank in a gsr block , the deck heights are the same</TD></TR></TABLE>
with what pistons? gsr's perhaps...
Old Jul 9, 2005 | 04:10 PM
SlwGsr's Avatar
im just curious, why would u wanna put ls bottom end in a gsr block? but ya i think it will fit
projectTeG's Avatar
you should use b16...the drop right on with no mods....gsr/type R pistons, the rod small ends need to be shaved
Old Jul 9, 2005 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">you should use b16...the drop right on with no mods....gsr/type R pistons, the rod small ends need to be shaved</TD></TR></TABLE>The b16 what? block? I already have the gsr block and head.
Old Jul 9, 2005 | 04:31 PM
projectTeG's Avatar
oops i mean the pistons....they go onto the ls rods with no mods, you allready have the p30s?....also upgrade the rod bolts on the ls rods
Old Jul 9, 2005 | 04:41 PM
AllMotorDan's Avatar
im curious too in why you would do this?
Old Jul 9, 2005 | 04:47 PM
longer stroke makes more torque, and whats going to stop it from reving high like it did before? theres no mechanicle factor holding it back.
Old Jul 9, 2005 | 04:54 PM
projectTeG's Avatar
the rod bolts on the ls rods are weak and wont last long under the abuse of reving like a gsr engine....so you replace them so they can handle the abuse
Old Jul 9, 2005 | 05:00 PM
already planing on using arp head and rod studs.
Old Jul 9, 2005 | 05:20 PM
projectTeG's Avatar
kool,,,,good luck on the build, im in the process of building a ls all motor, just need to get the time to put it together...lol
Old Jul 9, 2005 | 05:27 PM
I know someone who is selling a FULLY built ls head for a good price. It is really FULLY built.. IM me on aim if you're interested.
Old Jul 9, 2005 | 07:39 PM
doood's Avatar
been there done that
Default Re: (SpoonSirG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSirG &raquo;</TD></TR><TR><TD CLASS="quote">im curious too in why you would do this?</TD></TR></TABLE>its basically an lsvtec using a gsr block that comes with a girdle and oil squirters.
Old Jul 9, 2005 | 08:05 PM
i see
Old Jul 10, 2005 | 12:48 AM
Default Re: (sticky icky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky &raquo;</TD></TR><TR><TD CLASS="quote">its basically an lsvtec using a gsr block that comes with a girdle and oil squirters. </TD></TR></TABLE>indeed
Old Jul 10, 2005 | 12:55 AM
Sack Master's Avatar
Default Re: (JDM MonopolyMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky &raquo;</TD></TR><TR><TD CLASS="quote">its basically an lsvtec using a gsr block that comes with a girdle and oil squirters. </TD></TR></TABLE>Also you don't have to plumb the vtec line. But I believe the oil squirters need to be machined for the stroke of the ls crank. Wouldn't know never done it. But why go with stock honda stuff? Going through the trouble throw a good set of pistons and rods in the and abuse the **** out of it.
Old Jul 10, 2005 | 03:12 AM
jdm samurai's Avatar
Default Re: (Sack Master)
never knew you could do ls/vtec that way
Project_EK
Jun 5, 2008 09:17 PM
grand champ
Feb 20, 2008 10:10 AM
knuckk
Jan 14, 2008 11:19 AM
HpRevolution
12
Nov 9, 2006 05:36 AM
Quicky
Nov 25, 2002 05:12 PM
