oil temp..... help
Old Jul 9, 2005 | 01:11 PM
mark_is_gay's Avatar
Default oil temp..... help
i searched didnt really find soemthing to answer my question................. i heard people tap there oil pans to install oil temp gauges then i heard its not good to tap ur oil pan and put the sensor there. i own electrical gauges and iam not sure where to put the oil temp sensor....... anyone? and i rather not tap my oil pan so iss there anyother way that it would work properly and function well? help me out
92 cx hb with a jdm b18c if that helps.............
Old Jul 9, 2005 | 04:03 PM
Default Re: oil temp..... help (mark_is_gay)
ttt
Old Jul 9, 2005 | 09:30 PM
specv5150's Avatar
I plan on tapping mine to the oil filter sandwich dealie I got. It has 3 ports so turbo feed, oil temp and pressure., I can let you know how it goes tomorrow
Old Jul 9, 2005 | 09:47 PM
sinister6's Avatar
Majority of people will choose to tap it to oil filter sandwich ..
if you want absolute reading of your oil, tap it to oil pan..
I have heard people say oil pan oil temp will have 5-10 degrees C difference than in oil filter sandwich, I dont know. so last time my gauge shows me 134C i wonder if its really a 124C...
Old Jul 9, 2005 | 09:55 PM
specv5150's Avatar
Default Re: oil temp..... help (sinister6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">Majority of people will choose to tap it to oil filter sandwich ..
I have heard people say oil pan oil temp will have 5-10 degrees C difference than in oil filter sandwich, I dont know. so last time my gauge shows me 134C i wonder if its really a 124C... </TD></TR></TABLE>
yeah i thought about tapping the pan but too much work. I only bought the damn thing because I misread and though ti was a pressure gauge, then didnt feel like sending th ebitch back. Havent been able to sell it, so I guess I can live with a 5-10 degree difference.
Old Jul 10, 2005 | 10:03 AM
Default Re: oil temp..... help (specv5150)
yeah can u post pics or let me kno what tools are needed to tap the oil filter part? i would appreciate it.
its cause my headers seem hella close to my oil pan and i want to keep an eye out on the temp to make sure cause iam not trying to destroy the motor.
anyone kno how to tap an oil pan? or have any writte ups?
Old Jul 10, 2005 | 10:22 AM
specv5150's Avatar
http://cgi.ebay.com/ebaymotors...=WDVW
the exact one I have. That is all you need besides the sender for the gauge. If you buy a new gauge (or already bough tone) it should everything needed to plug into the sandwich. And the sandwich comes with everything needed to go between the oil filter and the block. And it also has screws to block off any unused ports.
Old Jul 10, 2005 | 10:26 AM
nice thanks a lot dude i will just get one of these as well......... i have defi gauges there electronic
Old Jul 11, 2005 | 05:51 AM
sinister6's Avatar
Try to avoid when this happened...
Old Jul 11, 2005 | 01:35 PM
dam thats hot............. where u tracking ur car? if u dont midn me asking did u install those gauges urself? if u did where did u tap the wires on those defi gauges i have the same ones but i cant install them cause iam not to handy when it comes to elec. wires. and whats a safe oil temp or the highest it should get before u shut the engine off thanks
Old Jul 11, 2005 | 07:25 PM
sinister6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mark_is_gay &raquo;</TD></TR><TR><TD CLASS="quote">dam thats hot............. where u tracking ur car? if u dont midn me asking did u install those gauges urself? if u did where did u tap the wires on those defi gauges i have the same ones but i cant install them cause iam not to handy when it comes to elec. wires. and whats a safe oil temp or the highest it should get before u shut the engine off thanks
Yes,I was tracking, its a good thing that Defi have a warning beep setups. I didnt realy pay much attention to the warning beep at 120C until going straight line to take a peep at it.. all I see is 130 degrees and up. so i kept my rpm below 6k for another 2 laps to get t down to 105 around.
for the sensors, i got the shop to do it for me, but i dont think its much trouble to DIY. just plug them and run the wires into the car from the hole beside the battery.
plug them to Link Control and just wire up electricity and the gauges..
Engines best operation temp = 90 C around, I think oil temp anywhere higher than 120 is consider high..over 130 is in the red zone..
I have done 142 once with POS HKS PRO NA Racing Oil.. oil pressure drop to minimum of 90kpa and warning beep keep telling me not enough oil press.
and then i start my car later on the same day and the day after..oil press hit skyrocket at 850-950kpa at cold start..need oilk change immediately.
Old Jul 12, 2005 | 05:16 PM
how much did the shop wnat to install them? thanks for all help by the way............ what kinda oil do u run?
Old Jul 12, 2005 | 06:14 PM
sinister6's Avatar
well i know the shop and this is Taiwan not the States. i have no idea how much it will run you to get them installed by a shop, but it cost me total of 110 bucks to get them installed plus some DIY
I am running Mugen VT Pro at this moment, wont use them again, not very good. going back to Motul 300V after my 3000kms are done..
Old Jul 12, 2005 | 10:25 PM
thanks for the tips man............... apreciate them
Old Jul 12, 2005 | 11:31 PM
bbarbulo's Avatar
I tapped my pan for the turbo oil return, it's not that hard. drill hole, weld bung, thread the sensor into the bung.
Old Jul 13, 2005 | 12:18 PM
Default Re: (bbarbulo)
i dont have those tools to tap my oil pan and iam not sure where to go to get it done or how much it will cost..............
hey sinister6a one question i looked into the gem oil adapter but it says its for a turbo set up. can i use a golden eagle oil sandwich plate? just want to kno if this is the unit ur talkin about.
Vtec-Mini
Nov 26, 2011 04:23 PM
BoostedH23a1
Oct 28, 2002 08:34 PM
BoostedH23a1
Oct 24, 2002 07:56 AM
Tofurky
Jul 9, 2002 10:15 PM
