Need axle removal help ASAP!!
Old Jul 9, 2005 | 08:58 AM
Bird333's Avatar
Default Need axle removal help ASAP!!
I am in the middle of trying to change out the passenger side axle on my 96 LX Accord sedan. This is what I have done. I got the axle nut off, and the ball joint out of the lower arm. I have NOT taken loose the damper fork. I think I have pryed the axle out of the tranny far enough. I can barely touch the smallest piece of the axle. I think I have about a 1.5" to 2" of the axle still in the tranny. I can't pull on the inboard joint of the axle enough to get it out of the tranny!!!! :madfawk: There is nothing I can really brace the prybar against to try to pry it out. Maybe I haven't popped it past that 'clip' but I thought I did. Everything was going pretty well until this.
I need suggestions!!!!!
TIA
Old Jul 9, 2005 | 11:37 AM
Chiovnidca's Avatar
Default Re: Need axle removal help ASAP!! (Bird333)
Have you pulled the axle out of the hub/knuckle assy?
Old Jul 11, 2005 | 05:21 PM
Jazzersizer's Avatar
You need to pry out the axle from the tranny using a pry bar or a screwdriver. It sounds like you have done everything right, you just have to pull it out
Old Jul 12, 2005 | 06:23 AM
raceACCORDingly's Avatar
i use a ball joint remover-pickle fork looking thing and wedge it between the tranny and inboard and it pops right out. you have the other out the hub so it has room to play right?
Old Jul 12, 2005 | 09:01 AM
turboH22Aakkord's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">i use a ball joint remover-pickle fork looking thing and wedge it between the tranny and inboard and it pops right out. you have the other out the hub so it has room to play right?</TD></TR></TABLE>
yeah, you can definetly use a pry bar between the tranny and axle... it has a little clip on the end of it i think... it should pop right out with a lil assistance... good luck...
j4s0n1337
Dec 22, 2010 08:26 AM
xingyun
Nov 30, 2008 02:06 PM
bara6075
Jul 14, 2007 11:03 PM
undertheradar
10
Aug 21, 2006 07:17 AM
CivicVX94
20
Sep 6, 2004 05:31 PM
