water pump question...already searched
Old Jul 9, 2005 | 12:33 AM
hitvtecgetloud09's Avatar
Default water pump question...already searched
so i did an ls-v swap and noticed my gsr water pump was leaking..so i took my old b16 one..now i want to know if there both the same..because they both say 22t on them ive heard they are diff...but i counted both and they both have 22 teeth
and also it says 22t...someone back me up on this...
BTW i failed to mention that im having problems with the timing belt sittin correctly on the cam gears...
Old Jul 9, 2005 | 12:42 AM
DumpedSi's Avatar
Default Re: water pump question...already searched (hitvtecgetloud09)
If you use a gsr water pump you have to use a gsr timing belt vice versa with the B16...
Old Jul 9, 2005 | 12:44 AM
Default Re: water pump question...already searched (Slammed Si)
well im using a gsr timing belt and i have a b16 water pump...will this not work/?
Old Jul 9, 2005 | 12:47 AM
DumpedSi's Avatar
No you need to go back to a gsr water pump or get a b16 timing belt
Old Jul 9, 2005 | 12:48 AM
but why is that..if both water pumps have 22 teeth and are the same? unless im wrong..but they do both say 22t
Old Jul 9, 2005 | 01:01 AM
DumpedSi's Avatar
Dont know the technical reason why but I've experienced it first hand plus have been told by a few people plus if you're trying to put it on and it isnt lining up that should be a clear indication that their not the same.. Get the corresponding water pump or t-belt and I'm most positive it will work
Old Jul 10, 2005 | 05:07 PM
can some one clarify this information becuz i have heard that they both are the same..and i have also head they are diff...autozone says the timing belt part number is the same for both...
cincyb20ek
May 5, 2010 04:51 PM
94sol
May 4, 2006 06:00 PM
hitvtecgetloud09
14
Jul 12, 2005 06:43 AM
TheSwift1
Apr 10, 2004 01:46 AM
built562
May 4, 2003 07:27 PM
