Camber Kit???
Old Jul 8, 2005 | 10:00 AM
CalgaryAccord's Avatar
Default Camber Kit???
Ok I just installed the Eibach Sportlines onto my 95 Accord EX. The drop was def. what I was looking for, but when I took it in to get an allignment the guy is telling me I need a camber kit. I was told it would most likely be ok with these springs. Is it possible to just do the allignment and get away with it. I mean I will be switching to winter tires in the winter anyways, and then back and forth like that. I would rather not spend the money, but if i have to I will. Any advice would be appreciated.
Old Jul 8, 2005 | 10:44 AM
sj993's Avatar
Default Re: Camber Kit??? (CalgaryAccord)
I don't remember how much the sportlines drop the car. If it's not more than 2" then you shouldn't need a camber kit.
Old Jul 8, 2005 | 10:53 AM
13lue's Avatar
I think you could go without the camber kit, but your tires are gonna wearout faster.
Old Jul 8, 2005 | 11:38 AM
I think they dropped just under two inches. There is defintley a negative camber there, but I think they could correct it a little with an allignment. I really dont want to have to spend the money. How bad/dangerous is it to drive with the negative camber. I use my car for a daily driver.
Old Jul 8, 2005 | 11:43 AM
turboH22Aakkord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CalgaryAccord &raquo;</TD></TR><TR><TD CLASS="quote">Ok I just installed the Eibach Sportlines onto my 95 Accord EX. The drop was def. what I was looking for, but when I took it in to get an allignment the guy is telling me I need a camber kit. I was told it would most likely be ok with these springs. Is it possible to just do the allignment and get away with it. I mean I will be switching to winter tires in the winter anyways, and then back and forth like that. I would rather not spend the money, but if i have to I will. Any advice would be appreciated.</TD></TR></TABLE>
hey man... just toss a camber kit in there... its easy as hell to install and it will save you tons of money on tires in the long run... i regret not putting mine on sooner.. just my .02 cents... good luck man..
Old Jul 8, 2005 | 12:02 PM
Default Re: Camber Kit??? (turboH22Aakkord)
OK thanxs man! Do you have any recommendations, on what type to buy! I saw some on ebay that were fairly cheap, but I dont really know what to look for. Also is the installation easier than doing the springs themselves, because that was a bit of a pain :-) Thank you for your input!
Old Jul 8, 2005 | 12:11 PM
If somone could take a look on Ebay and tell me what kits would work for my car. When I search Camber Kit Accord.... A few show up! one from Drop Zone, looks like a decent price, the eibach ones are way more expensive, and then there is some cheaper R1 Racing ones. What kit would i be smart to go with?
Old Jul 8, 2005 | 01:16 PM
fuglycord's Avatar
ingalls is another brand you might want to look into. but definitely get a set for the front cus in the long run you'll save $$ on tires. and use the washer trick for the rear
Old Jul 11, 2005 | 05:37 AM
i just used an ebay one... all the backs are are just two longer bolts with some washers... but the fronts i used took the place of the block things on the uper wishbone piece.. it came with new bushings and everything.. i think i paid like 100 for it... but it was worth it...
Old Jul 11, 2005 | 06:12 AM
jb.'s Avatar
jb.
Default Re: (fuglycord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuglycord &raquo;</TD></TR><TR><TD CLASS="quote">ingalls is another brand you might want to look into. but definitely get a set for the front cus in the long run you'll save $$ on tires. and use the washer trick for the rear</TD></TR></TABLE>
i got ingalls, and they went in pretty easily with a little persuasion. i got them from ultrarev and paid a total of 100 bucks or somewhere around there
Old Jul 11, 2005 | 01:50 PM
XprincoX's Avatar
Default Re: (jbkiksass69)
watchout for that control arm problem with the anchor bolt type of camber kit. I got the ingalls kit and i had to remove a piece of my fender wall...
Old Jul 12, 2005 | 05:45 AM
Default Re: (XprincoX)
yeah, with my camber kit, it rubbed the end of the uper ball joint off fron hitting on the iner fender of the wheel well... it was noisy for a few days till it wore away... no problems since though...
Old Aug 2, 2005 | 05:21 PM
subgeniusdude's Avatar
Default Re: (turboH22Aakkord)
Sportlines lower the 94-94 Accord 1.7 and 1.5.I have them on my 94 Accord sedan and running 17's w/205-40-17's and the front tires are ate up on the inside,but looking from the front,you can barely see any negative camber.The rears wear well though.I don't really like the anchor bolts from what I've heard,the adjustable ball joints seem like a better way to go to me.
PiZZaBoY7000
Dec 8, 2011 04:05 PM
TegoDC5
15
Oct 20, 2004 10:01 AM
DC4 teg
Dec 17, 2003 04:17 PM
xstalkrx
Mar 20, 2003 01:12 AM
PatrickGSR94
Feb 28, 2002 04:49 PM
