checking p28 ecu
Old Jul 8, 2005 | 08:21 AM
Mr.Death's Avatar
Default checking p28 ecu
Is there a way to check to see if my p28 is damaged or not without trying another p28? I have a solid cel and have ruled out everything but the computer. Any help is greatly appreaciated...
Old Jul 8, 2005 | 08:22 AM
germz's Avatar
Default Re: checking p28 ecu (Mr.Death)
try opening the cover up and see if anything is burnt....
Old Jul 8, 2005 | 08:24 AM
Mr.Death's Avatar
Default Re: checking p28 ecu (germz)
I did that and everything looks good.
Old Jul 8, 2005 | 02:31 PM
Relic1's Avatar
is the ECU chipped? (common problem, remove J1 or try a different chip)
by solid CEL you mean even with the service connector jumpered right? (just checking)
Old Jul 9, 2005 | 06:20 PM
Mr.Death's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">is the ECU chipped? (common problem, remove J1 or try a different chip)
by solid CEL you mean even with the service connector jumpered right? (just checking)</TD></TR></TABLE>
Yes the ECU is chipped and I tried removing J1 but the CEL is still constant. My car is a CRX with a d16z6 motor using a obd obd1 conversion harness which comes with a wire to jump with a ground source in which to check for codes. I tried jumping these wires to try and check for codes but the CEL remains constant.
Old Jul 9, 2005 | 06:50 PM
DumpedSi's Avatar
Default Re: (Mr.Death)
If you can just check your p28 on someone elses car or try another ecu on your car..
turbodcxbro
Engine Management and Tuning
12
Jun 1, 2013 04:14 AM
digitaldetox
Oct 5, 2010 07:23 PM
drshottest718
May 22, 2006 04:31 PM
1CiViC1
24
Sep 14, 2004 03:22 PM
ArinX
Feb 17, 2003 01:02 AM
