wastegate settings?
Old Jul 7, 2005 | 08:44 PM
95turbogsr's Avatar
Default wastegate settings?
I know the spring in the wastegate releases at the set pressure but if you have a boost controller set at 12 psi and psi spring in the waste gate for say 15 -20 will the wastegate open at 12?? ive looked through some threads and i believe that it will work like that but i just wanted to make sure
Old Jul 8, 2005 | 05:59 AM
95turbogsr's Avatar
Default Re: wastegate settings? (95turbogsr)
Anyone?>
Old Jul 8, 2005 | 07:57 AM
vaporboy12's Avatar
it will boost to whatever your spring is
Old Jul 8, 2005 | 12:27 PM
95turbogsr's Avatar
Default Re: wastegate settings? (vaporboy12)
Well if you have an ebc wont it realease where that is set too? like a 15 spring but the ebc is set at 10, so will it realease at 10 or 15?
Old Jul 10, 2005 | 09:11 AM
vaporboy12's Avatar
no the it cant control under what the wastegate is
Old Jul 10, 2005 | 09:40 AM
beepy's Avatar
The EBC can only increase boost above what the spring is rated at.
.RTErnie
Jul 15, 2006 10:06 AM
Harassing Herbs
Mar 1, 2004 08:31 PM
1 POINT 8
Jan 13, 2004 04:16 PM
Neukin
Aug 27, 2003 08:19 PM
DOHCarp
Jun 29, 2002 11:30 AM
