EK rear disc conversion
Old Jul 7, 2005 | 12:05 PM
specificcivic's Avatar
Default EK rear disc conversion
I know that everybody is gonna say that this topic has been covered but no it hasn't! I actually searched. what I need to know is:
1) Will a rear trailing arm/disc set up off of a 92-95 si hb fit on an ek?
2) Will a rear trailing arm/disc set up off of a 90-93 integra ls/rs/gs work on an ek?
3) If I use either of these set ups:
a) which brake lines should I use?
b) which proportioning valve should I use?
c) which ebrake cable should I use?
BTW, this is going on a 96 Civic CX 3dr HB
cheers
Old Jul 7, 2005 | 12:11 PM
jdmsiR20's Avatar
Default Re: EK rear disc conversion (specificcivic)
Honda-Tech.com » Search » 8 topics found
» Search Results
Your search for rear disk returned 8 results.
https://honda-tech.com/zerothread?id=1259074
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longbeachpurplecivic &raquo;</TD></TR><TR><TD CLASS="quote">99-00 civic si will fit
92-95 civic si/ 94-95 ex will fit using your LCA
94-01 integra will fit using your LCA
ive got one from a 99 integra ls but youre all the way over there </TD></TR></TABLE>
Honda-Tech.com » Search » 313 topics found
» Search Results
Your search for rear disk returned 313 results.
https://honda-tech.com/zerothread?id=152884
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragII &raquo;</TD></TR><TR><TD CLASS="quote">these reposts are getting out of hand.....everyone post whatever info you know on brake swaps so we can refer back to this post when the inevitable repost occurs.
I for one know that....
GSR/LS/99-00 civic SI rear brakes are the SAME
when doing a rear disk conversion you can get the prop valve, and MC from the teg, but you don't HAVE to....
I don't have them on mine, and it works fine.
use of integra parking brake cables is fine.
you don't HAVE to buy the whole trailing arm assemby...the trailing arms are the same....it is just easier than swapping out the spindal, and installing all brake components.
Integra front rotors are the same size as EX front rotors...Integra Calipers are bigger.
that's all I got right now...feel free to add</TD></TR></TABLE>
Old Jul 7, 2005 | 12:13 PM
Captain_Kicker's Avatar
Default Re: EK rear disc conversion (jdmsiR20)
the H-T search function sux my ballzack
Old Jul 7, 2005 | 12:16 PM
Deemeetree's Avatar
Electrician
Actually, it has been covered:
https://honda-tech.com/zerothread?id=641639
If you want more FAQs, go here:
https://honda-tech.com/zerothread?id=642479
Happy reading.
Davidkak
15
Jan 11, 2011 02:29 PM
K24EK
Suspension & Brakes
Sep 23, 2005 06:14 AM
Civic97s
Jun 8, 2005 04:30 AM
chue_li
11
Mar 31, 2004 09:59 AM
92hybridhhatch
Feb 7, 2003 10:51 AM
