how do i change tranny fluid in my gsr....
i did the search could find a write up....i was told to take the passenger wheel off then drain from the side... then take the speed sensor off and pour oem tranny fluid....anybody have a write up with pictures?
the speed sensor is the easy way of refilling the tranny.Once you drain put the bolt back in, now remove the filler bolt. Remove the speed sensor, and use a funnel to fill the tranny. It takes about 2.2-2.3qt to fill it, once you get the second Qt in start to watch the filler hole. As you pour the third qt in you will see some oil start to come out of the filler hole. Once this happens put the filler bolt back in, speed sensor back in and you are done.
It is really easy to do!!
nfinitecc
Dec 3, 2004 03:47 PM
team2n1hatch
Jun 30, 2003 04:00 PM
