How do I rewire the 02 sensor on an 88 crx si? Weird yellow wire?
From: South Bay, Torrance/Carson, CA, United States
I swapped a Zc into my 88 crx si using the Si wire harness. All the wires and plugs on the harness is cool except fot the 02 sensor--its missing. All that is left of where I think the 02 plug is supposed to be is a yellow wire. However, there is something unusual about the yellow wire. It appears that this yellow wire is coming out of a black colored wire that is also cut. It looks like a wire coming out of another wire. Any help is appreciated.
ill say run it straight to ur computer and ull save urself alot of trouble thats what u want right to connect it to work with ur computer just get a wire and plug it to ur comp and that would work just make sure u connect it to the right pin
hope this helps
hope this helps
Anyone have a link to a diagram of a pg7 ecu? So I basically run one wire from the 02 sensor to the correct pin on the ecu? It's as simple as that?
chrismanis
Nov 6, 2014 12:07 PM
streetstylenperformance
Feb 26, 2004 03:28 PM
AdamITR
May 14, 2003 05:44 PM
