so i got this b16a2 from a junkyard (need help first engine)
hello everybody.
so i just came back from the junkyard with this b16a2.
i dont know its condition so im gonna overhaule it. (not my self/in a shop)
this is my first engine that i buy so be delicat with me
please take a look in the picturs and tell me what are the components that are missing on this engine.
here is a list of the things that i know thats missing:
-DIZZY
-alternator
-throttle cable
-full engine wiring (the idiots just cut the wiring )
-engine pully.
now its your turn.... tell me if you see anything missing.
best regards moshik galimidi
-DIZZY
-alternator
-throttle cable
-engine pully.
thanx....
so here are the pictures....
http://www.imagestation.com/album/?id=2124140826
Member Name: racepak
pass: kwsband
Modified by RACEPAK at 3:21 PM 7/6/2005
pass: kwsband
Is that the only picture you have?
From this very unhelpful pic, it looks like you're missing a transmission, flywheel, thermostat housing, and flywheel bolts.
Edit: Nevermind, forgot to sign in. (Use photbucket or something, cuz not everyone has imagestation)
TPS is broken. Alternator tensioner bracket, driver's side mount, rear trans bracket, EVAP purge valve, MAP sensor, crank pulley, and exhaust b-pipe are also missing. Oh, and that kind of looks like an OBD1 fuel rail with OBD1 injectors, so are you sure that's a B16A2 and not a B16A3?
Modified by slomofo at 7:14 PM 7/6/2005
that is a good condition longblock from a salvage yard. at least int eh pics.
i also agree that it appears to be obd1 injectors.
the price is quite good as well if you ask me.
anyway a typical salvage yard will sell a longblock as the engine with no accessories, no throttle body, nodistributor, no crank pulley, no flywheel, and the harness and hoses will be cut.
their assumprtion is that you are putting the engine into the same model car that it originally came from. probably the only reason they left the throttle body on was a broken tps...
RACEPAK
45
Jul 14, 2005 09:52 AM
