head?
Old Jul 6, 2005 | 08:13 AM
kgard's Avatar
Default head?
Well,
It seems like I'm going to have my headgasket replaced in my 91 REX SI. Since the head is going to be removed I saw two VTec heads in our local trading post. One is a VTEC SOHC D16Z6 and the other is a VTEC SOHC D16Y8. Is either of these worth purchasing for a mini-me conversion or is it a waste of money since eventually I'm going to go with a B16 swap.
Thanks.
Mourning over down time of REX.
Man this stinks.
Old Jul 6, 2005 | 08:16 AM
vegaskurt's Avatar
Default Re: head? (kgard)
Should give you about 15 to 20 hp with vtec. If you are planning on going B series then just save for that.
Old Jul 6, 2005 | 08:22 AM
kgard's Avatar
Default Re: head? (vegaskurt)
I was thinking about that also but I want to ride now. If I'm going to pay 500.00 to 1100.00 for the repair (depending on the condition of the head) I figured the mini-me conversion would keep me sane and since the seller only wants 70.00 for the head I might come out cheaper.
Old Jul 6, 2005 | 11:24 AM
manson's Avatar
if your not going to pickup a b series for an extended period of time why not just do the swap while you have the parts available to you now.
I don't know exactly how much HP your going to gain over the OEM setup, but if your going to have the head off already you may as well just do it if its not going to blow your $ situation out of wack.
reyrey2006
Feb 14, 2009 04:54 PM
bakerjsp
May 23, 2006 07:39 AM
Chicano
Jan 30, 2004 12:56 PM
jimakazi
Sep 9, 2002 11:15 AM
LoooseGSR
14
Mar 8, 2002 06:30 PM
