EGT probe in Blox manifold?
i had the inlinePRO tapped on the number 3 before, and i know the Blox is supposed to be a copy, but for some reason the number 3 runner just seems to be shorter than i remember.
so...
anyone have the number 3 runner tapped on the blox manifold for egt? i'm looking at it right now, and it looks like it might be a pretty tight fit. i just wanna make sure there is enough room before i make any mistakes.
i could do it on top, but only if i have to, i would prefer to tap the bottom of the manifold because i just think it looks cleaner.
Modified by NuclearB18B at 1:17 AM 7/6/2005
so...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT »</TD></TR><TR><TD CLASS="quote">why did you get rid of the inline pro</TD></TR></TABLE>
i got rid of my whole setup...i had to pay for school...but i'm going to be boosted again soon thanks to some crazy *** hailstorms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">mine is tapped on top of #3
There should be more room on the bottom.</TD></TR></TABLE>
well, on the inline pro, i had it tapped and the back of the egt probe was touching the exhaust housing on the turbo.
blox is not a copy of any manifold on the market. its a desgin of its own you cannot interchange downpieps from inlinepro/revhard over to blox it sits 1/4 inch lower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">blox is not a copy of any manifold on the market. its a desgin of its own you cannot interchange downpieps from inlinepro/revhard over to blox it sits 1/4 inch lower. </TD></TR></TABLE>
ricky at wiredspeed told me that and said the revhard dp is the dp i needed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuclearB18B »</TD></TR><TR><TD CLASS="quote">
ricky at wiredspeed told me that and said the revhard dp is the dp i needed...</TD></TR></TABLE>
if u want ill test fit some blox downpipes i got in stock into a revhard manifold tomarrow and let ya know
am i reading that right? you're going to test fit a revhard manifold on a blox downpipe? or did you mean revhard dp to a blox manifold?
</TD></TR></TABLE>am i reading that right? you're going to test fit a revhard manifold on a blox downpipe? or did you mean revhard dp to a blox manifold?
am i reading that right? you're going to test fit a revhard manifold on a blox downpipe? or did you mean revhard dp to a blox manifold?</TD></TR></TABLE>
blox downpipe onto revhard manifold
if you guys say they're the same. then they should interchange.
if you guys say they're the same. then they should interchange. </TD></TR></TABLE>
thats a good point, i didn't think about it like that. let me know if it works. otherwise, i may be in contact with you to buy a dp.
