New Motor rebuild now car wont start tried searching but nothing getting fuel and some spark
Old Jul 5, 2005 | 08:29 PM
Hockey27925's Avatar
Default New Motor rebuild now car wont start tried searching but nothing getting fuel and some spark
just got my new motor back gsr block sleeved forged internals and a built gsr head i put the timing belt on tried to crank over the motor and it wont start. i am deffinitly gettin fuel i have it at 40 psi, the battery was on a charger while cranking it (optima), and the motor tried to turn over but it sputters with wut seems to be a bad miss, it starts up for a few seconds but then dies out with me giving it some gas too, it has plently of gas, the spark plug wires are good, i put new plugs in it, and the dizzy is good cuz i used it back in october, help
Old Jul 5, 2005 | 08:42 PM
2gturboteg's Avatar
Default Re: New Motor rebuild now car wont start tried searching but nothing getting fuel and some spark (Ho
if you have spark and fuel you have a timing issue. hondas are simple if the timing is close and you have fuel and spark it will start
Old Jul 5, 2005 | 08:44 PM
2gturboteg's Avatar
you know i just had an idea. check your firing order thats probably it. that is the easiest mistake
Old Jul 5, 2005 | 10:22 PM
apok's Avatar
As it was said before, if you have fuel and spark, your timing is off. Make sure everything is lined up at TDC (mechanical and electrical) and make sure your plug wires are in the correct firing sequence (Helms manual).
Also, make sure sensors are connected. We were working on a JDM H22 in an Accord. All timing was fine, everything was in order. It would start, smoke, choke, and die. Turned out we missed the MAP sensor since its on the firewall. It runs fine now.
Old Jul 6, 2005 | 06:54 AM
everythign is lined up correctly on the tioming belt, the firing order on the injectors and the plugs wires are good too, does anyone think it could be the dizzy since it was sitting for so long or no
Old Jul 6, 2005 | 08:15 AM
ROOROWNS's Avatar
pul a plug wire, put a screwdriver in the plug wire, check for spark on every cylinder then you will know if your Dizzy is working. Check back in after doin this.
Sean
Old Jul 6, 2005 | 10:38 AM
Default Re: (DA_Black_Hatch)
did the spark check and i am getting spark in every cyclinder
Old Jul 6, 2005 | 08:08 PM
Default Re: (Hockey27925)
bump for answers
Old Jul 6, 2005 | 08:22 PM
2gturboteg's Avatar
if you have fuel and you have spark it must be timing
distributors dont just go bad they wear out. what is the firing order you are using and what plug on the cap are you using for no 1 and are you going clockwise with your firing order or counter clockwise?
how did you determine tdc on the crank? and on the cams?
Old Jul 6, 2005 | 09:30 PM
Default Re: (2gturboteg)
the firing order is fine i checked that a few times , but i lines up the crank by the marks on the oil pump housing and the cams had both the teeth pointing straight up and lined up even with the oil passage way for the head, i have skunk2 cam gears kinda tricky to align
Old Jul 6, 2005 | 09:55 PM
2gturboteg's Avatar
pull out the no 1 plug and make sure the piston is at tdc by feel
then pull off the cam gear bolts and make sure the keyways are both pointing up
Old Jul 13, 2005 | 05:30 PM
i got it all running right it was the timing belt i pulled it off and redid it and it works but stalls out aftyer start up
Old Jul 18, 2005 | 07:17 PM
2gturboteg's Avatar
yup its still off
Herbie
Apr 21, 2010 09:57 AM
kuztomwerxauto
23
Nov 9, 2009 05:21 PM
TwoKSiR
Apr 23, 2009 03:54 AM
Bo0steDC4
Oct 10, 2008 02:31 PM
2kTeg
Feb 12, 2006 06:14 PM
