type r ecu in gsr
Old Jul 5, 2005 | 06:02 PM
envious1320's Avatar
Default type r ecu in gsr
Can I plug and play a obd2 jdm type r ecu in my obd2 gsr. I have a skunk2 intake manifold so I don't need the second intake runners to switch on since I don't have them or is there a better option thanks
Old Jul 5, 2005 | 06:15 PM
adaml2nv's Avatar
Default Re: type r ecu in gsr (envious1320)
yup. i'm running mine with one and i'm selling my old ecu in my sig.
Old Jul 5, 2005 | 06:20 PM
Default Re: type r ecu in gsr (adaml2nv)
All you did was plug it in. I thought I read somewhere it might not match up because the pins would be in diffrent spots but I thought I would ask here to make sure.
Old Jul 5, 2005 | 07:00 PM
adaml2nv's Avatar
yeah it's a plug and play. but you have to have the right year ecu to go with the car
Old Jul 5, 2005 | 08:36 PM
1whitedc2's Avatar
what else did you add to your car to take full advantage of the itr ecu? other than just single stage IM, or itr (or aftermarket) cams...?
Old Jul 5, 2005 | 08:48 PM
NathanMorris's Avatar
Default Re: (1whitedc2)
be basically the same thing as installed a chipped ecu program or something along those lines ...
be nice if you had at least the itr cams though.
Nathan
Old Jul 5, 2005 | 09:01 PM
I found one that is a 96-98 and I have a 96 gsr that should work right and its jdm I know what jdm is but will the pins be in diffrent spots because it is jdm
Old Jul 5, 2005 | 09:35 PM
BlackSage's Avatar
Im guessing with the itr ECU you will be able to rev to 8400RPM?
Old Jul 5, 2005 | 09:48 PM
phateless's Avatar
is that the only advantage to an itr ecu? if you plug an itr ecu onto a stock gsr are there any benefits to had?
iH8RICERZ's Avatar
Default Re: type r ecu in gsr (BlackSage)
if you have a 96 integra, you'll need to find a obd2A ITR ecu 96-99. The 00-01 ITR/GSR have an immobilizer in the ecu and will not plug into your stock 96 harness unless you run a obd2A-obd2B conversion harness. What would be ideal is getting a 98 ITR ecu. I believe my friend is selling one. PM me if you want more details.
Old Jul 5, 2005 | 09:59 PM
apok's Avatar
Default Re: (phateless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote">is that the only advantage to an itr ecu? if you plug an itr ecu onto a stock gsr are there any benefits to had?</TD></TR></TABLE>
Maybe 2-3 WHP over stock.
The ITR ECU isn't what makes the power. The port and polish, better cams, pistons, head design, and intake manifold are what make the power.
Build your head and you'll see much better gains than the ITR ECU.
Old Jul 6, 2005 | 06:26 AM
smkngsr's Avatar
Default Re: (apok)
ITR ecu is ok...but if you have an extra cash, id just get a P28 from IH8RICERZ...its a lot different from a stock ITR ecu...and the timing is more aggressive...im not sayin the ITR ecu is a bad choice but id save more cash and get a P28...
MaGoodc2
Apr 16, 2006 08:15 PM
ViperbitGSR
Jul 9, 2003 10:13 PM
smkngsr
Oct 8, 2002 01:25 PM
smkngsr
Aug 5, 2002 05:02 PM
Brian*
Apr 5, 2002 11:22 PM
